27/06/2018
The Benefits of Using TPU material in Elastomeric Part Designs
By Tony Holtz
what is tpu material - A moulded TPU part
Thermoplastic polyurethane has excellent chemical and abrasion resistance.
So, you’re designing a part that requires flexibility and you need to choose a material. You might first spring to your familiar list of thermoplastic elastomers, but don’t forget about thermoplastic polyurethane materials, commonly known as TPU. Depending on your application’s requirements, TPU might be your best option.
What is TPU Material?
TPU is an elastic thermoplastic material with high abrasion and chemical resistance. Like most elastomers, it’s commonly used for seals, gaskets, and hoses. It can also be found on overmoulded plastic parts due to its ability to add grip or dampen vibration. It’s similar to TPE, but offers more durability for parts that will experience wear and tear.
TPU Advantages
The chemical and abrasion resistance of TPU material makes it suitable for applications in rugged environments. For example, gaskets in under-the-hood automotive applications or industrial machinery are often made from TPU since it holds up well when it comes in contact with oil and fuel. The material’s high impact resistance has also made it a popular option for protective smartphone cases and other electronics housings.
Choosing the Right TPU
Chemical composition of the TPU material will vary based on whether it is a polyester- or polyether-based TPU. A polyether-based TPU is generally used when high hydrolysis and microbial resistance is critical or when fluctuating temperatures are present, especially at low temperatures. With many trade names and options on the market, it’s important to read through the material data sheets when choosing TPU—or better yet, contact a resin supplier and discuss your application with an expert. The chart below can get you pointed in the right direction.
Properties Polyester-Based TPU Polyether-Based TPU
Abrasion resistance
Excellent
OK
Mechanical properties
Excellent
Good
Low temperature flexibility
OK
Excellent
Chemical resistance
Excellent
Poor
Hydrolysis resistance
Very Poor
Excellent
Microbial resistance
Very Poor
Good
TPU and Other Flexible Material Options
Primarily, TPU materials are molded, which offers you a range of material and quantity options.
Read this design tip to explore elastomers further and learn more about your flexible material options. If you have a need for or have questions if your parts may benefit from TPU, please contact an application engineers at 01952 683047 or customerservice@protolabs.co.uk, or visit our material comparison guide.
