MJF 3D Printed Part
Multi Jet Fusion (MJF)
Multi Jet Fusion (MJF) 3D printing can build quality nylon parts suitable for rapid prototyping and production.
Multi Jet Fusion is an industrial 3D printing process that produces functional nylon prototypes and end-use production parts in as fast as 1 day. Final parts exhibit quality surface finishes, fine feature resolution, and ‬more consistent mechanical properties when compared to processes like selective laser sintering.
Common applications for Multi Jet Fusion are:
  • parts requiring consistent isotropic mechanical properties
  • functional prototypes and end-use parts
  • complex and organic geometries with fine features
Multi Jet Fusion Design Guidelines & Capabilities
Materials for multi jet fusion 3D printed parts
MJF Material Options
PA 12 Black
PA 12 Black is a high tensile strength nylon. Final parts are dyed black, and they exhibit quality surface finishes and slightly more isotropic mechanical properties when compared to SLS. When more detail is required, PA 12 can achieve smaller minimum feature resolution 0.5mm as compared to SLS materials 0.75mm PA 12 Smooth Light Grey is the best material option for designs that incorporate living hinges.
Primary Benefits
  • Near isotropic mechanical properties
  • Economical material choice
Datasheet
PA 12 Glass Beads Black
PA12-Glass Beads Black is a 40% glass bead polyamide with excellent stiffness and dimensional stability. The material possesses higher thermal resistance than unfilled polyamides and exhibits excellent long-term wear resistance. Due to the glass additive, it has decreased impact and tensile strengths compared to other nylons.
Primary Benefits​
  • Stiffness and dimensional stability
  • Long-term wear resistance
  • High-temperature resistance
Datasheet
PA 11 Black
PA 11 Black provides excellent ductility and temperature resistance without sacrificing tensile strength. It offers one of the highest elongation break thresholds in the nylon family.
Primary Benefits
  • Isotropic Mechanical Properties
  • Enhanced Elongation at Break
  • Water and airtight without any further treatment
Datasheet
UltrasintTM TPU-01 - 88A Black
This thermoplastic polyurethane (TPU) combines rubber-like elasticity and elongation with good abrasion and impact resistance. Ideal for automotive components due to its high chemical resistance to oil and grease. Also possessing high UV resistance. Showing high accuracy and detail resolution, supporting optimisation of lattice structure designs.
Primary Benefits
  • Flexibility
  • Tear and Abrasion Resistance
  • High Durability
Datasheet
Compare MJF Material Properties
Material Colour Tensile Strength Tensile Modulus Elongation
PA 12  Black 49 MPa ± 4 MPa 1900 MPa ± 200 MPa 12% ± 4%
PA 12-Glass Beads  Black 30 MPa ± 5 MPa 2500 MPa ± 400 MPa 10 ± 5%
PA 11 Black 52 MPa 1800 MPa 35%
UltrasintTM TPU01 - 88A Black 9MPa ± 2MPa 75 MPa >220%
Guide for surface finishes on MJF parts
Our 3D Printing surface finish guide provides you with a quick overview of our finishing options and what you can expect when your 3D-printed parts arrive.
3DP Surface Finish Guide
About Multi Jet Fusion
Multi Jet Fusion: What is it used for?
For fast, quality results, Multi Jet Fusion (MJF) is unparalleled as a 3D printing process. It’s able to produce functional nylon prototypes and end-use production parts in a single day, featuring quality surface finishes and fine feature resolution. It also offers more consistent mechanical properties than similar processes like selective laser sintering.
Using an inkjet array to repeatedly apply fusing agents across a bed of nylon powder, followed by fusion into a solid layer via heating elements, MJF is able to offer complex and detailed features. Protolabs offers a commercial-grade unfilled Nylon 12 material to create durable parts. Multi Jet Fusion offers a fast and advanced way to create parts on demand. Discover more with this short video.
Get a Quote
Get a quote for MJF 3D Printing Services
Get A Quote
