Order custom SLS parts suitable for rapid prototyping and end-use production.
Certifications ISO 9001:2015 | ISO 14001:2015 | ISO 13485 (Protolabs Network)
Selective laser sintering (SLS) is an industrial 3D printing process that produces accurate prototypes and functional production parts in as fast as 1 day. Multiple nylon-based materials and a thermoplastic polyurethane (TPU) are available, which create highly durable final parts that require heat resistance, chemical resistance, flexibility, or dimensional stability. With SLS 3D printing, no support structures are required making it easy to nest multiple parts into a single build and an economical solution for when higher volumes of 3D-printed parts are required.
Common uses for selective laser sintering are:
- jigs and fixtures
- housings
- snap fits and living hinges
Selective Laser Sintering (SLS) Materials
PA 12 White
expand_less expand_morePA 12 White is an economical material choice for functional prototypes and end-use parts. It offers high impact and temperature resistance, is very durable, and remains stable under a range of environmental conditions. The nylon material exhibits a white finish with a slightly rougher surface texture compared to other nylons.
Primary Benefits
- Strength and stiffness
- Well-balanced material properties
PA 12 Glass Filled White
expand_less expand_morePA 12 40% Glass-Filled is a polyamide powder loaded with glass spheres that add stiffness and dimensional stability. The material possesses higher thermal resistance than unfilled polyamides and exhibits excellent long-term wear resistance. Due to the glass additive, it has decreased impact and tensile strengths compared to other nylons.
Primary Benefits
- Stiffness and dimensional stability
- Long-term wear resistance
- High-temperature resistance
PAx Natural
expand_less expand_morePAx Natural is a versatile polyamide which is characterised by excellent toughness and flexibility in any direction, including the z plane. The material possesses great long term stability and durability and can be used to produce both prototyping as well as end-use parts.
The material is very versatile, so applications range from living hinges and snap fits to fixtures, enclosures as well as orthotics.
Primary Benefits
- Excellent toughness and durability
- High impact and high elongation
- Long-term stability
PA 12 - Carbon Filled Black
expand_less expand_morePA 12 Carbon-Filled is an anthracite grey nylon characterised by extreme stiffness and high-temperature resistance, coupled with electric conductivity properties and lightweight. It can be used for both functional prototypes and end-use parts. The carbon-fibre filler provides different mechanical properties based on the considered three-axis direction. This material exhibits a good surface quality and smoother finish compared to other SLS nylons.
Primary Benefits
- Extreme stiffness
- Electrical conductivity
- Excellent long-term stability
TPU-88A Black
expand_less expand_moreThis thermoplastic polyurethane (TPU) combines rubber-like elasticity and elongation with good abrasion and impact resistance. It can be leveraged to produce both prototypes and functional parts. The material’s rubber-like quality is ideal for seals, gaskets, grips, hoses, or any other application where excellent resistance under dynamic loading is required.
Primary Benefits
- Tear and abrasion resistance
- Flexibility
- Durability
Compare Material Properties
Material | Colour | Tensile Strength | Tensile Modulus | Elongation |
PA 12 (PA 650) |
White | 50 MPa ± 4 MPa | 2000 MPa ± 200 MPa | 11% ± 4% |
PA 12 Glass Filled | White | 42 MPa +/- 4 MPa | 3600 MPA +/- 400 MPa | 5% +/- 2% |
PA x Natural | Natural | 40 MPa+/- 5 MPa | 1300 MPa +/- 200 MPa | >60% |
PA 12 - Carbon Filled* | Black | 85 MPa ± 5 MPa | 8300 MPa ± 400 MPa | 3.2% ± 2% |
TPU-88A* | Black | 20 MPa ± 5 MPa | 520% ± 50% |
* X plane
Our 3D Printing surface finish guide provides you with a quick overview of our finishing options and what you can expect when your 3D-printed parts arrive.
3DP Surface Finish GuideResources
