Anodising and Chromate Plating for Machined Parts
Strengthen, protect, and improve appearance of parts with post-process finishing
Finished Parts in as Fast as 5 days
Get machined parts anodised and chromate plated with our quick-turn finishing option. Eligible materials include aluminium 6082 and 7075. Start your next machining project today.
Anodising
Our anodising processes are typically applied to machined aluminium parts to reduce corrosion and add an appealing metallic colouring to the porous aluminium substrate. Anodising helps parts resist scratching, is a natural electrical insulator, and is one of the most durable finishes available. We offer three specific types of quick-turn anodising options to protect your parts:
Decorative Anodising ISO 7599 equivalent to -Type II
Hard Anodising ISO 10074 equivalent to - Type III (hard coat)
Chromate Plating
Chromate conversion coating protects your parts from corrosion by chemically changing the properties of the metal. It also offers electrical connectivity and the ability to paint the part. Our chromate plating is Chromate Conversion Non-Hexavalent | SurTec(R) 650.
Anodising and Chromate Plating Specifications
Anodise | Hard Anodise | Chromate |
Decorative Anodising | ISO 7599 |
Hard Anodising | ISO 10074 Equivalent to - MIL-A-8625 Type III, Class 2 (Black) |
Chromate Conversion Non-Hexavalent | SurTec(R) 650 Equivalent to - MIL-DTL-5541 Type II, Class 3 (Clear) |
Quick-turn Finishing
Here are the requirements to get parts in as fast as 6 days (1-day expedite + 5 days for plating):
- Aluminium 6082 and 7075 material eligibility
- Threaded holes plugged
- No masking available
High-requirement Finishing
If you have more complex anodising and plating requirements, work with our digital network of manufacturers. The network works well for components that require a specialised colour or material option such as titanium or nickel.
