Liquid Silicone Rubber Injection Moulding
Get custom silicone rubber parts within days.
Certifications ISO 9001:2015 | ISO ISO 14001:2015 | Critical to Quality Inspections
Jump to Section
→ Capabilities
→ Materials
→ Surface Finishes
→ Quality Inspections
→ About Silicone Rubber Moulding
Our liquid silicone rubber (LSR) moulding process produces custom prototypes and end-use production parts in 15 days or less. We use aluminium moulds that offer cost-efficient tooling and accelerated manufacturing cycles. What's more, we stock various grades and durometers of LSR materials.
Common applications for silicone rubber moulding:
- low-volume production
- bridge tooling
- pilot runs
- functional prototyping
Quality Inspections and Finishing Options
Depending on your application's requirements, you can choose from the following when requesting a quote for your silicone rubber parts.
Quality Inspections available for on-demand manufacturing orders
- Designing for Manufacturability (DFM) Feedback
- Scientific Moulding Process Development Report
- In-process CMM inspection and machine monitoring
- First article inspection (FAI) and process capability report with GD&T
Learn More About Liquid Silicone Rubber Moulding
Our guide to liquid silicone rubber (LSR) discusses the injection-moulding process of the elastic material and offers guidelines to improve moulded LSR parts. While there are some shared similarities to thermoplastic injection moulding, LSR is a thermoset material with a unique set of design characteristics.
What is liquid silicone rubber moulding?
expand_less expand_moreLiquid silicone rubber moulding is a thermoset process that mixes a two-component compound together, which is then heat cured in the mould with a platinum catalyst to produce a final LSR part.
Why choose liquid silicone rubber moulding for your project?
expand_less expand_moreLiquid Silicone Rubber has excellent thermal, electrical, and chemical resistance properties, although it can be attacked by certain solvents such as gasoline or mineral spirits, which is why it can be used in high-temperature automotive applications but not for fuel lines. And it has low compression set—low permanent deformation when a force is applied and removed—making it ideal for elastomers. This allows for faster and most cost-effective tooling when compared to traditional steel moulds. We offer a number of additional secondary services to support your project.
How does liquid silicone rubber moulding work?
expand_less expand_moreFrom left to right, the components of a silicone rubber injection moulding press include: ram (1), screw (2), silicone rubber part A (3), silicone rubber part B (4) mixer (5), barrel (6), chilled silicone rubber (7), nozzle (8), heated mould (9). and thermoset part (10)
Due to the flexible nature of LSR, parts are manually removed from the mould, and thus, ejector pins are not built into the mould design. Like a standard aluminium tool, an LSR moulding tool is fabricated using CNC machining to create a high-temperature tool built to withstand the LSR moulding process. After milling, the tool is polished by hand to customer specifications, which allows six standard surface finish options.
The finished tool is loaded into an advanced LSR-specific injection moulding press that is precision geared for accurate control of shot size to produce the most consistent LSR parts.
Since LSR is a thermosetting polymer, its moulded state is permanent—once the rubber mould set, it can’t be melted again like a thermoplastic. When the run is complete, parts (or the initial sample run) are boxed and shipped shortly thereafter.
For more information on liquid silicone rubber (LSR) moulding process to help you improve your LSR moulded parts, read our LSR white paper.
Watch: Injection Moulding Process
Rapid injection moulding works best for on-demand production, bridge tooling, pilot runs, and functional prototyping. Our affordable aluminium moulds and quick turnaround times help reduce design risks and limit overall production costs.
Watch: From Art to Part
Watch an initial concept for a product move from sketch to 3D CAD model to final part. Once a design is uploaded at Proto Labs, we provide an interactive quote with real-time pricing information and manufacturability feedback within hours. Product designers and engineers can choose from various injection moulding, CNC machining and 3D printing manufacturing processes — all built to produce quick-turn parts in as fast as 1 day.
