Usinage CNC : Dimensions maximales en fonction des matières
5-axis-indexed milling | 3-axis 2-sided milling | Turning centre | |||||
Type | Material | X Y mm | Z mm | X Y mm | Z mm | Ø mm | Z mm |
Aluminium | Aluminium 2024-T3/T351 | 3.1355 | AlCu4Mg1 | 254 x 178 | 70 | 356 x 254 | 44 | Ø 75 | 228 |
559 x 356 | 32 | ||||||
Aluminium | Aluminium 5083-H111 | 3.3547 | AlMg4.5Mn0.7 | 254 x 178 | 93 | 559 x 356 | 44 | Ø 75 | 228 |
Aluminium | Aluminium 6082-T6/T651 | 3.2315 | AlSi1MgMn | 254 x 178 | 93 | 559 x 356 | 93 | Ø 75 | 228 |
Aluminium | Aluminium 7075-T6/T651 | 3.4365 | AlZn5.5MgCu | 254 x 178 | 91 | 559 x 356 | 91 | Ø 75 | 228 |
Aluminium | Aluminium 7075-T7351| 3.4365 | AlZn5.5MgCu | 254 x 178 | 91 | 559 x 356 | 91 | ||
Brass | Brass Cz121 (bar) | 2.0401 | CuZn36Pb3 | Ø 75 | 228 | ||||
Brass | Brass Cz112 (60/40) | 2.0321 | CuZn36Sn1 | 254 x 178 | 93 | 279 x 228 | 93 | ||
Carbon Steel | Carbon Steel EN8 | 1.0503 | Fe | 254 x 178 | 44 | 279 x 228 | 44 | Ø 75 | 228 |
Copper | Copper C101 | 2.0060 | Cu | 254 x 178 | 44 | 279 x 228 | 44 | ||
Mild Steel | Mild Steel S275JR | 1.0044 | Fe | 254 x 178 | 44 | 279 x 228 | 44 | Ø 75 | 228 |
Stainless Steel | Stainless Steel 17-4 PH | 1.4542 | X5CrNiCuNb16-4 | 178 x 178 | 44 | 178 x 178 | 44 | Ø 75 | 228 |
Stainless Steel | Stainless Steel 304/304L | 1.4304 | X5CrNi18-10 | 254 x 178 | 44 | 279 x 228 | 44 | Ø 75 | 228 |
Stainless Steel | Stainless Steel 316/316L | 1.4404 | X2CrNiMo17-12-2 | 254 x 178 | 44 | 279 x 228 | 44 | Ø 75 | 228 |
Titanium | Titanium Grade 5 | 3.7164 | Ti6Al4V | 254 x 178 | 44 | 279 x 228 | 44 | Ø 75 | 228 |
ABS | ABS Black | 254 x 178 | 93 | 279 x 228 | 93 | ||
ABS | ABS Natural | 254 x 178 | 93 | 356 x 254 | 44 | ||
Acrylic (PMMA) | TECACRYL Acrylic Transparent | 254 x 178 | 93 | 279 x 228 | 74 | ||
HDPE | TECAFINE PE100 Black | 254 x 178 | 93 | 279 x 228 | 93 | ||
HDPE | TECAFINE PE100 Natural | 254 x 178 | 93 | 279 x 228 | 93 | ||
Nylon | Nylon 6 SUSTAMID 6 FR Natural | 254 x 178 | 44 | 279 x 228 | 44 | ||
Nylon | Nylon 6 TECAST TM Black | 254 x 178 | 93 | 279 x 228 | 93 | ||
Nylon | Nylon 6 TECAST T Natural | 254 x 178 | 93 | 279 x 228 | 93 | ||
Nylon | Nylon 6 TECAMID GF 30% Black | 255 x 178 | 44 | 279 x 228 | 44 | ||
Nylon | Nylon 66 ERTALON GF30 Black | 254 x 178 | 93 | 279 x 228 | 93 | ||
Nylon | Nylon 66 TECAMID 66 Natural | 254 x 178 | 93 | 279 x 228 | 93 | ||
Nylon | Nylon 66 TECAMID GF 30% Black | 254 x 178 | 93 | 279 x 228 | 93 | ||
PBT | TECADUR GF 30% Light Grey | 254 x 178 | 70 | 279 x 228 | 74 | ||
Polycarbonate (PC) | TECANAT Translucent Natural | 254 x 178 | 93 | 279 x 228 | 73 | ||
PEEK | TECAPEEK Natural | 254 x 178 | 44 | 279 x 228 | 44 | ||
PEI | Ultem 1000 TECAPEI Natural | 254 x 178 | 44 | 279 x 228 | 44 | ||
PEI | Ultem 2300 TECAPEI 30% GF Natural | 254 x 178 | 44 | 279 x 228 | 44 | ||
PET | TECAPET / TECADUR | 255 x 178 | 93 | 279 x 228 | 93 | ||
PE-UHMW | TECAFINE PE1000 Natural (Opaque White) | 254 x 178 | 93 | 279 x 228 | 93 | ||
POM (Acetal) | Acetal Copolymer Black | 254 x 178 | 93 | 380 x 279 | 70 | ||
POM (Acetal) | Acetal Copolymer Natural | 254 x 178 | 93 | 279 x 228 | 93 | ||
POM (Acetal) | Acetal Copolymer SUSTARIN C FDA approved | 254 x 178 | 44 | 279 x 228 | 44 | ||
POM (Acetal) | Acetal Copolymer Static Dissipative (TECAFORM AH SD) Beige | 254 x 178 | 44 | 279 x 228 | 44 | ||
POM (Acetal) | Acetal Homopolymer | 254 x 178 | 32 | 279 x 228 | 44 | ||
PP | Homopolymer Natural | 254 x 178 | 70 | 279 x 228 | 74 | ||
PP | Homopolymer TECAFINE Beige | 254 x 178 | 93 | 279 x 228 | 93 | ||
PPSU | Radel R-5500 Black | 254 x 178 | 44 | 279 x 228 | 44 | ||
PTFE (Teflon) | TECAFLON White | 254 x 178 | 44 | 279 x 228 | 44 | ||
PVC | TECAVINYL Grey | 254 x 178 | 93 | 279 x 228 | 93 |
* 5-axis indexed milling (3 + 2 milling)
5 Axes
L’approche 5 axes* permet de travailler sur plusieurs faces pour fraiser des éléments sous différents angles, ce qui signifie qu’il est possible de fabriquer des pièces plus complexes.
Dans le cas de notre usinage 5 axes, il est important de souligner que la matière première utilisée est une barre (cylindrique). Nous avons mentionné le diamètre maximal, l’enveloppe de fraisage maximale correspondante est indiquée sur le schéma (66 mm x 73 mm x 99 mm). En cas de doute sur la dimension maximale, veuillez télécharger votre plan et nous vous fournirons des informations détaillées sur la fabricabilité.
Qu’est-ce que le fraisage 3 axes ?
Les 3 axes font référence aux mouvements X (gauche-droite), Y (avant-arrière) et Z (haut-bas) de l’outil. Des formes complexes peuvent également être générées, comme des pentes et des surfaces profilées. Une limitation est que les trous et les filetages doivent généralement être sur l’un des 3 axes.
Qu’entend-on par fraisage sur 2 et 6 côtés ?
Avec le fraisage 3 axes, la pièce et la broche/l’outil sont fixes l’un par rapport à l’autre. Plus il est possible de traiter des éléments depuis un seul côté, mieux c’est (à la fois pour le temps de fabrication et la précision). Protolabs propose le fraisage des 6 côtés (imaginez le percement de trous dans un dé) sur la plupart des matières. En raison de leur taille, des composants de plus grande dimension peuvent n’être accessibles que de deux côtés (le haut et le bas ou l’axe Z)
Qu’est-ce qu’un centre de tournage ?
Un centre de tournage est un tour qui possède également des capacités de fraisage, ce qui vous permet de réaliser des pièces beaucoup plus complexes. La principale considération est la conception d’un « plan de joint ». Il s’agit de la dernière face à usiner et elle doit idéalement être plate. Cette face peut être usinée avec un deuxième réglage. Consultez notre page de tournage CNC pour plus d’informations.
