ABS Lustran Update & FAQ
As a valued customer, we want to keep you in the loop on a material change.
On October 30, 2024, Ineos Styrolution announced their intention to permanently close their Addyston, Ohio operations. As of now, we have received notification of the discontinuation of Lustran branded ABS materials.
While this decision is outside of our control, we understand the potential impact it may have on your projects. Our team is here to support you in identifying alternative materials and solutions to ensure continuity in your production. We will work closely to find the best path forward.
Affected Materials
Lustran 433, Lustran 348, and Lustran 248
Materials Currently Available at Protolabs (supplies are limited)
- Lustran 348 (Natural)
- Lustran 348 (Snow White)
- Lustran 433 (Natural)
- Lustran 433-010276 (White)
Now Obsolete:
- Lustran 433 (Black)
- Lustran PG298 (Platable)(Light Gray)
- Lustran 248 (White)
Why Protolabs?
Speed
Protolabs can help qualify new materials faster than anyone in the world — with parts in as little as one day. No delays.
Reliability
Our digital process, scientific molding and in-line CMM inspection, FAI and capability studies ensure we manufacture quality parts consistently—making requalification a smooth process.
Cost
Our robust aluminum tooling delivers an affordable option, while maintaining the quality needed for production programs.
Comparing Alternatives to ABS Lustran
Want to source and use your own materials? At Protolabs we accept customer supplied materials that meet our material requirements. Learn More →
Lustran 348
Alternative Material | Material Overview | Material Features | Protolabs Stocked | Data Sheet |
Lustran 348 (original material) | Medium impact strength and good tensile properties. It is especially suitable for medical applications | Healthcare certifications, high gloss, medium impact, meets FDA modified ISO 10993-1 requirements, meets U.S. Pharmacopeia 23 Class VI test requirements, UL classification 94HB | Fully Stocked with Material | Lustran 348 White |
HI121H-0B585 WT (LG Chem) | Direct equivalent to Lustran 348-012002. | USP class VI medically approved, US FDA food contact approved, EU food contact regulation No. 1935/2004, (EU) No. 10/2011 | Coming Soon | HI121H-0B585 WT |
Novodur HD 348 WT (Ineos) | Very similar, excellent impact properties. (Medical grade approval expected March/April 2025.) | High gloss surface finish, broad processing window, excellent balance of impact and stiffness | No (Protolabs will accept customer supplied material) | Novodur HD 348 WT |
PA-704LRP | Low residual monomer, medical application. White only | Medical and healthcare applications, low residuals | No (Protolabs will accept customer supplied material) | PA-704LRP |
Lustran 348 (original material) | Medium impact strength and good tensile properties. It is especially suitable for medical applications | Healthcare certifications, high gloss, medium impact, meets FDA modified ISO 10993-1 requirements, meets U.S. Pharmacopeia 23 Class VI test requirements, UL classification 94HB | Fully Stocked with Material | Lustran 348 Natural |
Novodur HD 348 NR (Ineos) | Designed for medical devices. It provides a combination of high gloss, stiffness, and impact strength. | High gloss surface finish, broad processing window, excellent balance of impact and stiffness. | Yes | Novodur HD 348 NR |
HI-121H NP (LG Chem) | HI-121 ABS are direct equivalents to Lustran | General purpose, impact resistance | No (Protolabs will accept customer supplied material) | HI-121H NP |
Polylac PA-757F (ChiMei) | Low residual monomer, food application | Food contact acceptable, low residuals | Yes | Polylac PA-757F |
Lustran 433
Lustran 433 White (original material) | General-purpose injection molding grade of ABS. It is an high impact, high-gloss ABS, available only in natural (NR) and black (BK904000) | High impact strength, high gloss, UL95 HB rated | Fully Stocked with Material | Lustran 433 White |
Terluran GP22 NR | Easy-flow, general purpose injection molding grade with high resistance to impact and heat distortion; intended for a wide range of applications, particularly in the housings sector. | Excellent colorability, medium flow, good impact resistance, good heat distortion resistance, high quality surface finish and gloss, great mechanical strength and rigidity | Yes | Terluran GP22 NR |
PA-717C NAT | Medium impact | Medium impact resistance, UL94 HB rated 1.5mm | No (Protolabs will accept customer supplied material) | PA-717C NAT |
Novodur 433 NR | Superior mix of high gloss and impact compared to standard ABS. It combines excellent toughness and stiffness for the most challenging injection molding applications. | High gloss surface finish, broad processing window, excellent balance of impact and stiffness | No (Protolabs will accept customer supplied material) | Novodur 433 NR |
Lustran 433 Natural (original material) | General-purpose injection molding grade of ABS. It is an high impact, high-gloss ABS, available only in natural (NR) and black (BK904000) | High impact strength, high gloss, UL95 HB rated | Fully Stocked with Material | Lustran 433 Natural |
Novodur 433 NR | Superior mix of high gloss and impact compared to standard ABS. It combines excellent toughness and stiffness for the most challenging injection molding applications. | High gloss surface finish, broad processing window, excellent balance of impact and stiffness | Yes | Novodur 433 NR |
Lustran 433 Black (original material) | General-purpose injection molding grade of ABS. It is an high impact, high-gloss ABS, available only in natural (NR) and black (BK904000) | High impact strength, high gloss, UL95 HB rated | Obsolete | Lustran 433 Black |
Terluran GP22 BK | Easy-flow, general purpose injection molding grade with high resistance to impact and heat distortion; intended for a wide range of applications, particularly in the housings sector. | Excellent colorability, medium flow, good impact resistance, good heat distortion resistance, high quality surface finish and gloss, great mechanical strength and rigidity | Yes | Terluran GP22 BK |
PA-717C BK | Medium impact | Medium impact resistance, UL94 HB rated 1.5mm | No (Protolabs will accept customer supplied material) | PA-717C BK |
Novodur 433 BK | Superior mix of high gloss and impact compared to standard ABS. It combines excellent toughness and stiffness for the most challenging injection molding applications. | High gloss surface finish, broad processing window, excellent balance of impact and stiffness | Yes | Novodur 433 BK |
Lustran 248
Lustran 248 (original material) | General-purpose injection molding grade offers a good balance of physical properties. | High gloss, good rigidity, medium impact strength, UL94 HB rated | Obsolete | Lustran 248 |
