Compare CNC Machining Materials
*The information contained herein are typical values intended for reference and comparison purposes only. They should NOT be used as a basis for design specifications for quality control.
Units
US
Metric
Expand Allexpand_all
Collapse Allcollapse_all
AND
ABS
Strength
Cost Effective
Stiffness
More Detailsexpand_circle_down Less Detailsexpand_circle_up
ABS is a low-cost engineering plastic that is easy to machine. ABS is an ideal material for structural applications when impact resistance, strength, and stiffness are required. It’s widely used for pre-production prototypes since it has excellent dimensional stability and is easy to paint and glue.
Tensile Strength
41,369 kPa 6,000 PSI
Impact Strength
411 J/m 7.7 ft-lbs/in
Heat Deflection
94 °C 201 °F
Max. Part Size:
254mm x 177.8mm x 95.25mm 10 in. x 7 in. x 3.75 in.
ABS Flame Retardant
Strength
Cost Effective
Flame Resistance
ABS Flame Retardant is an ideal material for structural applications when impact resistance, strength and stiffness are required. ABS Flame Retardant is an economical engineering plastic when flame resistant properties are needed in prototyping.
Tensile Strength
37,921 kPa 5,500 PSI
Impact Strength
214 J/m 4 ft-lbs/in
Heat Deflection
88 °C 190 °F
Max. Part Size:
254mm x 177.8mm x 44.45mm 10 in. x 7 in. x 1.75 in.
Acetal 20% Glass Filled/Delrin 570
Strength
Temperature Resistance
Delrin 570 is a homopolymer acetal containing 20% glass fiber filler. It has very high stiffness, low warpage, and low creep for superior performance at elevated temperatures.
Tensile Strength
58,605 kPa 8,500 PSI
Impact Strength
152 J/m 2.85 ft-lbs/in
Heat Deflection
165 °C 329 °F
Max. Part Size:
POM (Acetal Copolymer)
Chemical Resistance
Dimensional Stability
Low Friction
Acetal is an engineering thermoplastic used in precision parts requiring high stiffness, low friction, and excellent dimensional stability.
Tensile Strength
60,674 kPa 8,800 PSI
Impact Strength
53 J/m 1 ft-lbs/in
Heat Deflection
158 °C 316 °F
Max. Part Size:
POM-H (Acetal Homopolymer)
Strength
Creep Resistance
Stiffness
Acetal Homopolymer is an engineering thermoplastic offering high mechanical strength, stiffness, hardness, and creep resistance. It often provides better wear resistance than Acetal Copolymer.
Tensile Strength
76,532 kPa 11,100 PSI
Impact Strength
80 J/m 1.5 ft-lbs/in
Heat Deflection
169 °C 336 °F
Max. Part Size:
POM (Acetal Static Dissipative)
Antistatic
Moisture Resistance
Wear Resistance
Acetal Static Dissipative is a semicrystalline engineering plastic with permanent antistatic additives for varied applications in electronics.
Tensile Strength
45,505 kPa 6,600 PSI
Impact Strength
101 J/m 1.9 ft-lbs/in
Heat Deflection
88 °C 190 °F
Max. Part Size:
CPVC
Heat Resistance
Corrosion Resistance
CPVC, also known as Chlorinated Polyvinyl Chloride provides excellent corrosion resistance at elevated temperatures making it ideal for self-supporting constructions where high temperatures are a concern.
Tensile Strength
50,332 kPa 7,300 PSI
Impact Strength
480 J/m 9 ft-lbs/in
Heat Deflection
92 °C 198 °F
Max. Part Size:
HDPE
Strength
Lightweight
Chemical Resistance
HDPE is a high-density polyethylene that is lightweight, has low moisture absorption, is chemical and corrosion resistant, and has high strength. It is great for applications such as orthotic and prosthetic devices, water storage, and tanks.
Tensile Strength
30,496 kPa 4,423 PSI
Impact Strength
69 J/m 1.3 ft-lbs/in
Heat Deflection
85 °C 185 °F
Max. Part Size:
LDPE
Lightweight
Flexible
LDPE is more flexible than HDPE, while still being light-weight and providing chemical and corrosion resistance. It’s extremely flexible making it great for prosthetic devices and thermoformed parts.
Tensile Strength
13,397 kPa 1,943 PSI
Impact Strength
No Break No Break
Heat Deflection
43 °C 110 °F
Max. Part Size:
Nylon 6
Strength
Wear Resistance
Nylon offers extremely good wear resistance, high tensile strength, and high modulus of elasticity, making it a great option in applications such as bearings, gears, and sprockets.
Tensile Strength
68,948 kPa 10,000 PSI
Impact Strength
37 J/m 0.7 ft-lbs/in
Heat Deflection
204 °C 400 °F
Max. Part Size:
Nylon 6/6
Lightweight
Fatigue Resistance
Noise Dampening
Nylon offers extremely good wear resistance and low frictional properties. It has very good temperature, chemical, and impact properties.
Tensile Strength
82,737 kPa 12,000 PSI
Impact Strength
59 J/m 1.1 ft-lbs/in
Heat Deflection
90-235 °C 194-455 °F
Max. Part Size:
254mm x 177.8mm x 19.05mm 10 in. x 7 in. x .75 in.
Nylon 6/6 GF
Strength
Stiffness
Heat Resistance
This 30% glass-fiber reinforced Nylon is important qualities such as high tensile and flexural strength, stiffness, and excellent heat deflection. Glass-fiber offers more than double the strength and stiffness of unreinforced nylons.
Tensile Strength
89,632 kPa 13,000 PSI
Impact Strength
96 J/m 1.8 ft-lbs/in
Heat Deflection
110-253.9 °C 230-489 °F
Max. Part Size:
Polycarbonate (PC)
Flame Resistance
Stiffness
Moisture Resistance
Polycarbonate is an engineering plastic that offers excellent dimensional stability over a wide range of service temperatures. It is commonly used for structural applications when clarity and impact strength are essential. It can also be used in a wide range of electrical applications since it has a low moisture absorption, good insulating properties, and an excellent flammability rating.
Tensile Strength
55,158 kPa 8,000 PSI
Impact Strength
91 J/m 1.7 ft-lbs/in
Heat Deflection
138 °C 280 °F
Max. Part Size:
Polycarbonate (PC) 20% GF
Electrical Properties
Stiffness
Impact Resistance
Polycarbonate 20% GF is a 20% glass reinforced polycarbonate with higher temperature and tensile properties than unfilled polycarbonate. Its good electrical properties combined with superior impact strength and moderate chemical resistance make it widely fitting for numerous applications.
Tensile Strength
110,316 kPa 16,000 PSI
Impact Strength
110 J/m 2.06 ft-lbs/in
Heat Deflection
148 °C 298 °F
Max. Part Size:
PEEK
Chemical Resistance
Heat Resistance
PEEK is a unique semi-crystalline, high temperature engineering thermoplastic. Its material properties provide a wide range of applications where thermal, chemical, and combustion are critical to performance. PEEK can retain flexural and tensile properties at very high temperatures.
Tensile Strength
96,527 kPa 14,000 PSI
Impact Strength
83 J/m 1.55 ft-lbs/in
Heat Deflection
141 °C 285 °F
Max. Part Size:
PEI ULTEM 1000
Strength
Stress Resistance
Heat Resistance
ULTEM is an amorphous thermoplastic polyetherimide (PEI) material that combines exceptional mechanical, thermal, and electrical properties. Natural ULTEM is a translucent amber color. Key attributes include excellent mechanical strength, ability to retain strength at elevated temperatures, high heat resistance, and high stress resistance.
Tensile Strength
104,800 kPa 15,200 PSI
Impact Strength
53 J/m 1 ft-lbs/in
Heat Deflection
200 °C 392 °F
Max. Part Size:
PEI ULTEM 2300 (30% glass-filled)
Strength
Stress Resistance
ULTEM is an amorphous thermoplastic polyetherimide (PEI) material that combines exceptional mechanical, thermal, and electrical properties. The addition of glass fiber reinforcement provides the material with greater tensile strength and rigidity while improving dimensional stability.
Tensile Strength
168,922 kPa 24,500 PSI
Impact Strength
85 J/m 1.6 ft-lbs/in
Heat Deflection
212 °C 414 °F
Max. Part Size:
PET
Strength
Wear Resistance
Chemical Resistance
PET, also known as Polyethylene Terephthalate, is a semi-crystalline thermoplastic polyester with excellent wear resistance, low coefficient of friction, high flexural modules, and superior dimensional stability. It it a very versatile option for mechanical and electro-mechanical parts.
Tensile Strength
86,184 kPa 12,500 PSI
Impact Strength
Heat Deflection
116 °C 240 °F
Max. Part Size:
PMMA (Acrylic)
Transparent
UV Resistance
Polymethyl methacrylate is a hard material sometimes referred to as Plexiglas™ and acrylic. It is often used as a lighter, shatter-resistant alternative to glass for its transparent appearance.
Tensile Strength
55,420 kPa 8,038 PSI
Impact Strength
24 J/m 0.4-0.5 ft-lbs/in
Heat Deflection
129 °C 264 °F
Max. Part Size:
254mm x 177.8mm x 95.25mm 10 in. x 7 in. x 2.75 in.
PP Copolymer
Cost Effective
Impact Resistance
Polypropylene (PP) Copolymer is a common thermoplastic often used for its versatility. It is easy to fabricate, will not crack with vibration or wear, and can also be used in applications that require chemical resistance and/or FDA compliance.
Tensile Strength
33,191 kPa 4,814 PSI
Impact Strength
416 J/m 7.8 ft-lbs/in
Heat Deflection
78 °C 173 °F
Max. Part Size:
PP Homopolymer
Chemical Resistance
Moisture Resistance
Polypropylene (PP) Homopolymer is a crystalline material with a high strength-to-weight ratio, excellent chemical resistance, and high performance in thermoforming and corrosive environments.
Tensile Strength
35,508 kPa 5,150 PSI
Impact Strength
64 J/m 1.2 ft-lbs/in
Heat Deflection
99 °C 210 °F
Max. Part Size:
PPE + PS Noryl 265
Flame Resistance
Impact Resistance
Moisture Resistance
This material is a modified PPO that is a strong engineering plastic with outstanding mechanical, thermal, and electrical properties. Some key attributes include low moisture absorption and low thermal expansion, making it one of the most dimensionally stable thermoplastics. It is often used for electrical housings due to its high flame resistance and excellent insulating properties.
Tensile Strength
63,432 kPa 9,200 PSI
Impact Strength
187 J/m 3.5 ft-lbs/in
Heat Deflection
123 °C 254 °F
Max. Part Size:
PPSU (Radel R 5500)
Flame Resistance
Heat Resistance
RADEL R polyphenylsulfone resins offer exceptional hydrolytic stability and toughness that is superior to other commercially available, high-temperature engineering resins. It offers high deflection temperature and outstanding resistance to environmental stress cracking. The polymer is inherently flame retardant, has excellent thermal stability, and good electrical properties.
Tensile Strength
69,637 kPa 10,100 PSI
Impact Strength
694 J/m 13 ft-lbs/in
Heat Deflection
207 °C 405 °F
Max. Part Size:
Polystyrene (HIPS)
Cost Effective
Machinability
Impact Resistance
High Impact Polystyrene (HIPS), is a low cost plastic material that is easy to machine. It is often used for low strength structural applications when impact resistance, machinability, and low cost are required. It is a great material choice for prototyping due to its dimensional stability and ability to paint and glue.
Tensile Strength
>20,684 kPa >3,000 PSI
Impact Strength
149 J/m 2.8 ft-lbs/in
Heat Deflection
85 °C 185 °F
Max. Part Size:
PTFE (Teflon)
Heat Resistance
High Density
Chemical Resistance
PTFE is a crystalline polymer commonly known by its trade name, Teflon. Properties include very high melting point and exceptional resistance to chemicals. Being hydrophobic, non-wetting, non-stick, high density, and resistant to high temperatures, it is incredibly versatile.
Tensile Strength
20,684-34,473 kPa 3,000-5000 PSI
Impact Strength
Heat Deflection
117 °C 243 °F
Max. Part Size:
PVC
Cost Effective
Machinability
Polyvinyl Chloride (PVC) is an extremely versatile polymer and used widely across many industries due to its exceptional corrosion resistance, high strength-to-weight ratio, and cost efficiency.
Tensile Strength
51,711 kPa 7,500 PSI
Impact Strength
53 J/m 1 ft-lbs/in
Heat Deflection
82 °C 179 °F
Max. Part Size:
UHMW
Chemical Resistance
Moisture Resistance
Ultra High Molecular Weight Polyethylene provides a unique combination of wear and corrosion resistance, low friction surface, and impact strength. It is resistant to chemical attack and moisture absorption and retains key physical properties in cold temperatures. It is also a cost-effective solution for food handling applications as it meets FDA and USDA guidelines.
Tensile Strength
39,990 kPa 5,800 PSI
Impact Strength
1,815 J/m 34 ft-lbs/in
Heat Deflection
82 °C 180 °F
Max. Part Size:
Aluminum 6061-T651/T6
Cost Effective
Aluminum 6061 is a versatile and widely used alloy renowned for its excellent mechanical properties and weldability. The "T6" and "T651" designations refer to specific tempering processes that enhance its strength and stress relief capabilities. Both variations of Aluminum 6061 are highly sought after in industries such as aerospace, automotive, marine, and general manufacturing due to their combination of strength, machinability, and corrosion resistance.
Tensile Strength
310 MPa 45 ksi
Elongation
17%
Hardness
95 HB
Max. Part Size:
599mm x 356mm x 95.25mm 22 in. x 14 in. x 3.75 in.
Aluminum 7075-T651/T6
Toughness
Ductility
Aluminum 7075 is an alloy with zinc as the primary alloying element. It has excellent mechanical properties and exhibits high strength, toughness, and resistance to fatigue. It has higher corrosion resistance than other aluminums, making it a great option for aerospace applications.
Tensile Strength
462-538 MPa 67-78 ksi
Elongation
3-9%
Hardness
150 HB
Max. Part Size:
Aluminum 7075-T7351
Toughness
Ductility
Tensile Strength
421-476 MPa 61-69 ksi
Elongation
6-7%
Hardness
135 HB
Max. Part Size:
Aluminum 2024-T351
Thread Rolling
Strength
Aluminum 2024 is heavily utilized in aircraft applications because it has good machining characteristics and higher strength than other aluminums. Its machinable properties are strong, making it essential for precision fittings and parts.
Tensile Strength
469 MPa 68 ksi
Elongation
19%
Hardness
120 HB
Max. Part Size:
Brass C260
Ductility
Brass is an alloy consisting of both copper and zinc. The gold material is weather and corrosion resistant with tensile strength like mild steel. It is also an easy to machine material, so feed rates can remain high and coolant need is minimal. Brass C260, or cartridge brass, contains 70 percent copper and 30 percent zinc. The brass alloy has high ductility and is considered the most general purpose of all brass alloys.
Tensile Strength
427 MPa 62 ksi
Elongation
30%
Hardness
70 HRB
Max. Part Size:
254mm x 177.8mm x 44.5mm 10 in. x 7 in. x 1.75 in.
Brass C360
Machinability
Brass is an alloy consisting of both copper and zinc. The gold material is a weather and corrosion resistant metal with tensile strength similar to mild steel. It is also an easy to machine material, so feed rates can remain high and coolant need is minimal. Brass C360 remains the industry standard for general machining and high-volume production.
Tensile Strength
400 MPa 58 ksi
Elongation
25%
Hardness
78 HRB
Max. Part Size:
Copper C101
High Conductivity
Ductility
Copper C101 is also known as HC or high conductivity copper. It has a nominal conductivity of 100% and has high thermal conductivity making it a popular choice for all types of electrical components and conductors. It also offers high ductility and impact strength, making it a versatile and useful material.
Tensile Strength
283 MPa 41 ksi
Elongation
14%
Hardness
40 HRB
Max. Part Size:
Low Carbon Steel (1018)
Cost Effective
Ductility
Low carbon steel, also known as mild steel, contains up to 0.30% carbon. This gives the material low strength while making it more malleable and ductile compared to high carbon steels.
Tensile Strength
448 MPa 65 ksi
Elongation
16-36%
Hardness
126 HB
Max. Part Size:
Stainless Steel 17-4 PH
Strength
Ductility
Stainless steel is well suited for a wide range of applications due to its excellent machinability and outstanding uniformity. It has good workability and weldability. This metal has very high tensile strength, and has high resistance to corrosion and wear.
Tensile Strength
1034 MPa 150 ksi
Elongation
8%
Hardness
33 HRC
Max. Part Size:
Stainless Steel 303
Weldability
Ductility
Stainless steel 303 is well suited fora wide range of applications due to its excellent machinability and outstanding uniformity. SS 303 was designed to exhibit improved machinability while maintaining high corrosion and oxidation resistance. It is a non-magnetic austenitic stainless steel which does not harden with heat treatment.
Tensile Strength
517-621 MPa 75-90 ksi
Elongation
35-50%
Hardness
228 HB
Max. Part Size:
Stainless Steel 304
Machinability
Ductility
Stainless 304 is the most common stainless steel. The steel contains both chromium and nickel metals as the main non-iron constituents. It has good resistance to oxidation, corrosion, and provides superior part surface quality.
Tensile Strength
683 MPa 99 ksi
Elongation
52%
Hardness
85 HRB
Max. Part Size:
Stainless Steel 316
Machinability
Cost Effective
Stainless steel 316 offers good machinability and outstanding uniformity. This material offers faster machining speeds, longer tool life, and improved part quality at a lower total cost.
Tensile Strength
586 MPa 85 ksi
Elongation
56%
Hardness
81 HRB
Max. Part Size:
Steel Alloy 4140
Toughness
Impact Resistance
Fatigue Resistance
Steel Alloy 4140 is a low alloy steel containing chromium, molybdenum, and manganese. It is widely used across numerous industries and is an excellent material choice for machining due to its toughness, high fatigue strength, and abrasion and impact resistance.
Tensile Strength
655 MPa 95 ksi
Elongation
26%
Hardness
92 HRB
Max. Part Size:
Titanium
Strength
Heat Resistance
Titanium is extremely strong and boasts a high strength-to-weight ratio. It also has excellent corrosion resistance, high operating temperatures (up to 1,000°F) and is nontoxic. Another key is its low thermal expansion and high melting point that is roughly 3,000° F. Machining titanium will be more costly than other metals such as aluminum.
Tensile Strength
952 MPa 138 ksi
Elongation
14%
Hardness
36 HRC
Max. Part Size:
There are no materials that match the selected combination of filters.
