November 7, 2024
Turning CAD Models into 3D-Printed Parts
Evaluating build direction, support structures, radii placement and wall thickness to optimize printed parts.
By Eric Utley
Applications Engineer
Because 3D-printed parts are built up layer by layer, designing CAD files for 3D printing can present unique challenges for engineers. Even the laws of gravity play a part! The following design considerations are critical to follow across all CAD software applications.
The Effect of Build Direction on 3D Printing
If you are designing or optimizing a part for 3D printing, the first decision to make is the intended build direction. While shorter heights typically translate into shorter build times and lower cost, in the end, accuracy and strength are usually more important.
In general, it is best to have the more detailed side of the part facing up during the print. Cylindrical features are most accurate with the cylindrical cross-section in the draw plane. Generally, the goals of optimization are to reduce the need for support material and to reduce the impact of material shrink that occurs from drastic changes in cross-section. Check out this article for more details on how orientation impacts 3D-printed parts.
CAD with bend
correct bend in 3DP CAD
If built like the image on the left, the up-facing cylinder will be more accurate than the one perpendicular to it. By rotating the model 45 degrees (right), both cylinders will be consistent. Note that a cut was made to give the part a flat base which would be supported during the print. Now, the cylinders are both built at a 45-degree angle and are self-supporting.
The 45 Degree Rule
For most additive technologies that require supports, surfaces 45 degrees and steeper are self-supporting. Eliminating unnecessary supports is a great way to mitigate costs, as any supports that are added also add to material cost, print time, and labor to remove. Some specific materials and processes may require 55 degrees or steeper to be self-supporting, while SLS and MJF do not require supports at all. For those two, this rule does not apply.
Add Radii to 3D Printed Parts
One of the easiest ways to improve accuracy and strength of 3D-printed parts is to add radii to all internal and external hard corners that the design allows. This can mitigate the material shrink that happens layer-by-layer, making the parts more accurate with less surface defects. It also spreads out stress that accumulates in interior corners and makes the parts stronger and less likely to crack under load.
For some materials and printing processes (like titanium printed via DMLS), radii are required to keep the parts from cracking during the printing process due to material shrink. Even a radius as small as 0.020 in. (0.5mm) can be enough to mitigate this risk.
bad example
better example
best example
You can add a fillet to eliminate a downfacing surface, but the part still will be quite thick. The center mass can be cored out to make the wall thickness more consistent. Add radii to smooth out the transitions.
Uniform Wall Thickness
Many printing technologies are susceptible to material shrink, which can affect tolerances and aesthetics. This is most noticeable when the parts undergo drastic changes in cross-section during the print. It is best to core out thick areas and leave the cavity accessible to the environment so that the supports or excess material can be removed after the print.
If printing in FDM, this rule can often be ignored. The partial infill of FDM allows parts to have a relatively uniform wall thickness, even if the CAD model itself undergoes large thickness transitions.
Still have questions about the best way to handle your application? Reach out to us at 877-479-3680 or [email protected]
