How to Choose Core and Cavity Placement in Injection Molding Parts
Determining how the part will be placed in the mold is critical in injection molding
How to choose core and cavity placement
An A-side (cavity) and B-side (core) of a mold are represented with the ejector plate and pins placed on the B-side.
One of the goals of rapid injection molding is to produce parts quickly. Proper design helps ensure that good parts will be produced on the first run. Determining how the part will be placed in the mold is critical. The overriding consideration is that the part must stay in the mold half that contains the ejector system.
Cavity and Core
In a typical injection molding machine, one half of the mold (the A-side) is attached to the fixed side of the press, and the other half of the mold (the B-side) is attached to the moving clamp side of the press. The clamp (or B) side contains the ejection actuator, which controls the ejector pins. The clamp forces the A and B-sides together, molten plastic is injected into the mold and allowed to cool, the clamp pulls the B-side of the mold away, the ejection pins are actuated, and the part releases from the mold.
Let's use a mold for a plastic drinking glass as an example. To ensure that the part stays in the mold half with the ejector system, we would design the mold so that the outside of the glass is formed in the cavity of the mold (A-side) and the inside would be formed by the core of the mold (B-Side). As the plastic cools, the part would shrink away from the A-side of the mold and shrink onto the core in the B-side. As the mold opens, the glass will release from the A-Side, and stay in the B-side, where it can be pushed off from the core by the ejector system.
If the mold design were reversed, the outside of the glass would shrink away from the cavity in the B-side and onto the core in the A-Side. The glass would release from the B-side and stick to the A-side where there are no ejector pins. At this point, we have a serious problem.
At Protolabs, our design staff uses software tools and extensive experience to make the correct A-side vs. B-side choice. On some parts, it is difficult to predict in advance which side of the mold the part will stick to. Well thought-out part design ensures that the part will naturally stick to the correct side of the mold.
Molded part with four holes
Two ways to mold the same geometry. Left: Deep rib molding uses milling to form part walls on the mold's B-side. Right: In core/cavity molding, the B-side's protruding core forms the interior of the part walls and the A-side forms the exterior walls.
A Rectangular Example
Let's consider a rectangular enclosure with four through holes. The outside of the enclosure will be a cavity in the A-side of the mold and the inside will be a core on the B-side. Design for the holes, however, could be handled in two different ways: They could be drafted toward the A-side, requiring cores in the A-side of the mold, but this might cause the part to stick to the A-side of the mold. A better approach would be to draft the cores to the B-side, ensuring that the part would stick to the B-side of the mold. Similarly, any tab or strip sticking from the part or spanning an internal hole should be drafted to the B-side to prevent sticking in the A-side and bending or tearing off when the mold opens. And, of course, the design should also avoid heavy texture on the outside of a part without adequate draft, as this could cause the part to stick in the A-Side.
As always, you can contact a Protolabs applications engineer at customerservice@protolabs.com.
cover of injection molding guide
Guide to Injection Molding
This guide walks you through everything from quoting, design analysis, and shipment to best practices that ensure your model is optimized for molding.
