3 Key Elements to Consider When Designing for Overmolding
Look at bonding, materials, and general moldability principles when creating overmolded parts
Injection molding is a common and cost-effective method for manufacturing parts. It’s widely used for everything from medical devices and children’s toys to household appliances and automobile parts, producing parts that are both strong and light, in many cases replacing machined or cast metal products.
Sometimes, however, injection-molded plastic parts need a little help. Low impact or vibration resistance, slippery surfaces, poor ergonomics, and cosmetic concerns are just a few of the reasons why a second molded part is often added as a grip, handle, cover, or sleeve.
Some manufacturers choose to assemble these two different molded components together with glue, screws, or an interference fit, but this takes time and costs money, and may lead to less-than-desirable results. Fortunately, the process of rapid overmolding offers an alternative solution.
This design tip explores three important elements of rapid overmolding:
- Bonding
- Materials
- Principles
What is Rapid Overmolding?
This process uses a mechanical or chemical bond (and oftentimes both) to permanently marry two parts together. This sidesteps assembly hassles, simplifies product design, and can improve the characteristics of many injection-molded parts.
At Protolabs, it works by placing a previously molded part—the substrate—back into the press and injecting a second plastic or liquid silicone rubber (LSR) over, into, and around the original part. The two-shot process requires a pair of molds—one for the substrate, and one for the complete, overmolded product. It also needs a human to tend the machine, loading substrate parts and unloading completed products, a process known as “pick-and-place” overmolding.
What’s next? Before embarking on any overmolding design project, several design considerations should be explored first:
- Bonding. A strong bond between the two materials is critical to overmolding.
- Materials. Substrate and overmold materials should be physically, chemically, and thermally compatible.
- Principles. The principles of moldability apply equally to overmolding, with a few additional considerations to keep in mind.
Bonding
Let’s start with bonding. In a perfectly overmolded part, the overlay is impossible to remove, and will tear before separating from the substrate, or even take some of the underlying material with it. The thermoplastics TPU and TPC, for example, form a strong chemical bond with ABS, polycarbonate, and PBT Valox (a type of polybutylene). Santoprene TPV, a tough but flexible “vulcanizate” widely used in weatherseal, food service, and wire and cable applications, is more restrictive, readily bonding to polypropylene but little else.
Achieving a high-level chemical bond isn’t always possible, though, nor even necessary in many cases. Consider a molded electronics housing cover with an overmolded gasket made of a soft sealing material. Once the cover is locked in place, the gasket has nowhere to go. All that’s needed is enough bond to hold the gasket to the substrate so it can’t fall out or be misplaced during assembly. This is an excellent application for overmolding, by the way, since it eliminates the need for a stamped paper or rubber gasket that must then be manually glued in place.
In most cases, we recommend a mechanical interlock to augment or even replace a chemical bond. This can be achieved by placing an undercut in the substrate part, or a series of reverse-tapered or counterbored holes into which the overmolding material can flow, assuring a no-fail mechanism in all but the most demanding applications. If you’re unsure how to add these features to your part design, contact one of our applications engineers at 877-479-3680 or customerservice@protolabs.com.
Material Compatibility Chart
Substrate Material | ||||||
Overmold Material | ABS Lustran | ABS/PC Cycolo C2950-111 | PC Lexan 940-701 |
PBT Valox 357-1001 |
PP Profax 6323 | Nylon 66 Zytel 103 HSL NC010 |
TPU - Texin 983-000000 |
C | C | C | C | M | M |
TPV - Santoprene 101-87 |
M | M | M | M | C | M |
TPE - Santoprene 101-64 |
LSR - Elastosil 3003/30 A/B |
- | - | M | M | - | M |
TPC - Hytrel 3078 | C | C | C | C | M | M |
TPE-Versaflex OM 1060X-1 |
C | C | C | M | M | M |
TPE-Versaflex OM 6240-1/td> |
M | M | M | M | M | C |
TPE-Versaflex OM 6258-1 |
TPE-Versaflex OM 1040X-1 |
M = mechanical bond (recommended)
C = chemical bond
Maximizing Material Choices
There are many reasons to overmold. One of the most common is to improve a product’s grip while retaining its physical strength—the handle on a power tool, for example, or a non-slip grip for a surgical instrument. In this case, TPU over ABS is an excellent choice. Aesthetics and product branding are also readily achieved with overmolding—a sports franchise might use the team colors in two-piece overmolded mouth guards for its players, while a well-known tractor manufacturer could dress up its riding lawnmowers with green and yellow overmolded cowlings.
LSR is another popular injection molding material. It offers excellent tensile and tear strength, is hydrophobic (repels water), flexible, bacteria and UV-light resistant, and biocompatible. About the only downside to LSR—at least in an overmolding situation—is its relatively high molding temperature of 350 degrees F (177 C), hot enough to soften substrate materials such as ABS, polyethylene, and others. Fortunately, polybutylene terephthalate (PBT) and glass-filled nylon hold up just fine. At Protolabs, we offer more than 100 engineering-grade thermoplastic and liquid silicone rubber materials, and dozens of colorants.
Following the Rules (Principles)
Overmolding reads from the same playbook as traditional injection molding processes, with a few additional idiosyncrasies:
- Proper draft angles, uniform wall thickness, and smooth transition lines must be maintained in both parts.
- The thickness of the overmold material should be less than or equal to that of the substrate below it.
- The melting temperature of the overmolding material should be less than that of the substrate (as in our LSR example).
- If chemical bonding isn’t practical, don’t despair. Mechanical interlocks are a great way to “hold it all together,” and should be used wherever possible.
- Texturing of the substrate workpiece may help with adhesion. Texturing of the overmolded part may provide a better grip and more attractive surface.
- The surface of the overmolded part should be even with or slightly below any adjacent substrate surfaces.
Overmolding is a great way to improve your product’s physical attributes or enhance its appearance. As with our other injection molding services, we produce cost-effective tooling with production quantities of 25 to 10,000 or more in about 15 days. If you’re looking to make millions of parts, rapid overmolding is also a great way to test prototypes for bonding and material compatibility prior to investment in two-shot production molds, or to serve as bridge tools until those molds are ready.
Because rapid overmolding is more complex than standard injection molding, the upfront tooling costs might be slightly higher than the sum of two molded and assembled components. Any additional investment is quickly absorbed, however, by the elimination of secondary assembly costs, as well as a higher quality, more durable product.
As always, feel free to contact us with any questions, at 877-479-3680 or customerservice@protolabs.com. To get your next design project started today, simply upload a 3D CAD model at protolabs.com for an interactive quote within hours.
