Draft Angle Guidelines for Injection Molding
Apply proper draft early and often to injection-molded parts to save production time and money
When developing parts for plastic injection molding, applying draft (or a taper) to the faces of the part is critical to improving the moldability of your part. Without it, parts run the risk of poor cosmetic finishes, and may bend, break, or warp due to molding stresses caused by the plastic cooling. Equally important, an absence of draft may prevent parts from ejecting from the mold, damaging not only the parts, but possibly the mold itself—a costly and time-consuming detour.
What is draft in injection molding?
Draft is a taper applied to the faces of the part that prevent them from being parallel to the motion of the mold opening. This keeps the part from being damaged due to the scraping as the part is ejected out of the mold.
Here are five ways that draft can improve part moldability.
Drafted and undrafted cubes
An undrafted (left) versus drafted (right) cube.
Incorporate Draft into Early Prototypes
Ignoring draft early in the design process is a common mistake that occurs when prototyping with 3D printing and CNC machining processes where draft is not required. Because of the layer-by-layer method in which 3D-printed parts are built, nearly any design can be produced with limited concern for moldability. The same can be said for machined parts as part ejection is a purely a molding consideration.
But if a prototype design will eventually move to injection molding, it is befitting to design draft into parts from the very beginning. Draft may alter the form and fit of a part during assembly and its overall aesthetic, so designing in draft, even when it’s not technically needed, can help you avoid any surprises such as costly redesigns and additional prototype development.
Design for the future need, not the current need. When the part is ready to move from 3D printing or machining into injection molding with draft already integrated, design is accelerated and production can begin sooner. Don’t print or machine yourself into a corner by manufacturing a product that needs more design work before it can be molded.
Basic Guidelines for Draft on Injection-Molded Parts
The truth is no single draft angle can be applied to all part designs. Factors like wall thickness, material selection, ejection, shrink rates, finish/texture, wall depth, and manufacturing capabilities all come into play. But fear not, there are some simple rules that can be followed that can help.
When designing a part, apply as much draft angle as possible—a general rule of thumb is 1 degree of draft per 1 inch of cavity depth, but that can change with the aforementioned factors. Try following these general guidelines:
  • 0.5 degrees on all vertical faces is strongly advised.
  • 1 to 2 degrees works very well in most situations.
  • 3 degrees is minimum for a shutoff (metal sliding on metal).
  • 3 degrees is required for light texture (PM-T1).
  • 5 or more degrees is required for heavy texture (PM-T2).
Feature Depth Minimum Thickness/Draft
0.25 in. 0.040 in./0.5°
0.5 in. 0.040 in./1° 0.060 in./0.5°
0.75 in. 0.040 in./2° 0.060 in./1°
0.080 in./0.5°
1 in.   0.060 in./2°
0.080 in./1°
 >0.100 in./0.5°
1.5 in.
0.080 in./2°
>0.100 in./1°
2 in.       >0.100 in./2°
What can be done when draft may negatively impact part performance? Parts can be designed with 0.5 degrees of draft, or even as little as 0.25 degrees, which is still an improvement over zero draft. Again, the smallest degree of draft that is possible is dependent on material, part geometry, and manufacturer and should be discussed with the manufacturer before finalizing a part with very limited draft.
Many low-volume injection tools are manufactured from aluminum and use CNC machining to mill nearly all of the features in the core and cavities of the mold. With fewer manufactured parts and inserts than a steel production mold, additional draft and wall thickness may be required to produce the same parts with an aluminum mold due to the diameter, length and draft of the end mills that are used to create them. The increase in draft and thickness typically won’t affect the parts, and it may actually improve the performance of eventual production mold
Deep-rib versus core-cavity
The deep-rib approach (left) and the core-cavity approach (right).
Implement a Core-Cavity Approach
Adding draft to an enclosure can create issues if it isn’t applied correctly. When applying draft to the inside and outside walls, design these walls parallel to each other to avoid deep ribs in the mold that make venting, ejection, mold finishing, and manufacturing more difficult. Consider a core-cavity approach to design as this opens up the mold cavity and core for polishing, accelerates manufacturing speed and, in general, brings added ease during the molding process.
Leverage (free) DFM Analysis
One of the most valuable tools available at Protolabs is our free design for manufacturability (DFM) analysis that is provided on every 3D CAD model that is uploaded to our site. Within a few hours, you’ll receive a quote that highlights detailed sections of the model in need of draft angles, and even offers suggested changes to improve the draft on those sections. It’s a good quality control check to help avoid future moldability issues.
Upload a 3D CAD for a complete analysis at protolabs.com. For questions on draft and technical concerns, please contact one of our knowledgeable applications engineers at [email protected] or 877-479-3680.
Illustration of drafted, undrafted walls
An undrafted wall with proper tool clearance (left), undrafted tall wall without proper tool clearance (middle) versus a drafted wall that provides adequate clearance for the end mill (right).
Factor in Surface Finish
How does draft affect parts finish? Simply put, with a lack of mold draft, the part would drag on the molded surface while the mold opens and ejects the parts, creating surface finish scratches. Since all thermoplastics shrink while they cool in the mold, a massive amount of surface tension is created, preventing the part from releasing cleanly during ejection. This tension creates small scratches in the polished surface, and it’s even worse for textured surfaces—if draft is missing.
Texture is applied many different ways, but they all create micro undercuts from pitting the mold surface. The texture on the mold walls would lock the part into place, if it weren’t for our old friend, draft. By applying a degree of draft, the part is allowed to move a short distance before the mold shrink is able to clear the micro undercuts, and ultimately the concern of mold drag or scratches on the part is minimized. On finishes, Protolabs requires a minimum of 3 degrees of draft for a light bead-blast finish (PM-T1) and 5 degrees of draft for a medium bead-blast finish (PM-T2).
Protolabs can apply seven different finishes to thermoplastic molds that range from unfinished to highly polished and even textured surfaces.
Frequently Asked Questions
What is draft in injection molding and why is it critical?
Draft is a slight taper on faces parallel to the mold’s opening direction. It reduces scraping and sticking during ejection, preventing cosmetic defects, warping, part breakage, and even mold damage.
How much draft should I use?
Apply as much as practical. General rules:
  • 0.5° on all vertical faces is strongly advised.
  • 1–2° works well for most situations; roughly 1° per 1 in. of cavity depth.
  • 3° minimum for shutoffs (metal-on-metal).
  • For texture: 3° for light bead-blast (PM-T1) and 5°+ for medium/heavy textures (PM-T2).
Final needs depend on material, wall depth, shrink, ejection strategy, and manufacturer capability.
Do I need to add draft to early prototypes if I’m 3D printing or machining?
Yes, design in draft from the start if the part will be molded later. Draft can affect form/fit and appearance; adding it early avoids costly redesigns and accelerates the transition to injection molding.
How does surface finish or texture influence required draft?
Without draft, parts drag and scratch during ejection; textures create micro-undercuts that can “lock” parts in the mold. Protolabs requires about 3° for light texture (PM-T1) and 5° or more for heavier textures (PM-T2) to release cleanly.
What if minimal draft impacts performance or I have deep walls/enclosures?
Limited draft (as low as 0.25°–0.5°) can work in some cases—discuss with your molder since feasibility depends on geometry and resin. For enclosures, keep inner and outer walls parallel and use a core-cavity approach to avoid deep ribs that complicate venting, ejection, and finishing. Note that aluminum prototype tools may need added draft and wall thickness due to CNC tool access. Protolabs’ free DFM will flag low-draft areas and suggest improvements.
cover of injection molding guide
Guide to Injection Molding
This guide walks you through everything from quoting, design analysis, and shipment to best practices that ensure your model is optimized for molding.
