Protolabs Product Release Notes
Discover our latest product releases, capability enhancements, and e-commerce upgrades
*United States only
Collapse Allcollapse_all
April 01, 2025
Add Custom Inspections to Your Molding Project
More Detailsexpand_circle_down Less Detailsexpand_circle_up
Our digitalized processes, scientific molding, and quality measures ensure both repeatability and quality.  We now offer a variety of inspection reports you can easily select within your Protolabs account.
Customizing inspections for your injection molding project allows for verification of numerous critical dimensions and gives you peace of mind. You’re able to select the desired number of features and samples you’d like measured.
Check out the help center to learn more about adding inspections to your project.
New Material: PA12 Value
New material option added to our Selective Laser Sintering (SLS) process called PA12 Value. PA12 Value is a great alternative to PA12 White, providing an off-white colored part with similar properties but at a lower price point. PA12 Value is a great option when your project requires functional and durable parts with no added finishing.
PA12 Value for 3d Printing
Upload a Part
February 25, 2025
ABS Lustran Update
On October 30, 2024, Ineos Styrolution announced their intention to permanently close their Addyston, Ohio operations. As of now, we have received notification of the discontinuation of Lustran branded ABS materials. Our team is here to support you in identifying alternative materials and solutions to ensure continuity in your production.
Here is the latest information on recommended material alternatives.
February 25, 2025
Quoting Platform
Easier Iterative Design with Part Renaming
We know that designing the perfect part often takes multiple revisions - new CAD files, adjustments, and refinements until you reach the final version.  To make this process smoother, we've added a Rename Parts feature inside eCommerce.
  • Keep track of different iterations by renaming parts as you refine the design
  • Avoid confusion by giving your final CAD file a clear, meaningful name
  • Stay organized while working through multipole design updates.
how to rename your parts
February 25, 2025
New Custom Finishing for 3D Printed Parts: Cerakote
Adding to our extensive list of custom finishing options for 3D printed parts, we've recently added Cerakote. Cerakote is a ceramic coating that can be applied to 3D printed parts in varying materials providing superior performance and functionality. It is also available in a wide array of colors. Cerakote can be used as an alternative to anodizing and painting providing a wide range of benefits on finished parts.
To evaluate the full list of Cerakote coatings visit here.
How to Order Parts with Cerakote Finishing
Step 1: In your quote configuration, select "custom" from the finish drop-down menu. From here you will be prompted to describe what type of finish you are looking for. This is where you will put coating selection from here.
use the custom finish field to add cerakote to your order
Step 2: By adding a request for custom finishing, this will trigger a manual review of a quote and an applications engineer will reach out to you to learn more about your part requirements and provide recommendations on a path forward.
add the cerakote number and name in the custom finish description
Step 3: You will receive a link that will bring you to a final quote that includes the custom finishing required. Place your order and wait for your custom finished parts to arrive!
