CNC Machining: Maximum Extents
Find the maximum extents of plastic and metal materials available for CNC milled and turned parts.
Material Maximum Extents
ABS Max. Depth: 3.75 in. (95.25mm)
ABS Flame Retardant Max. Depth: 1.75 in. (44.45mm)
Aluminum 6061-T651 Max. Depth: 3.75 in. (95.25mm)
Aluminum 7075-T651 Max. Depth: 3.75 in. (95.25mm)
Brass 260 Max. Depth: 1.75 in. (44.45mm)
Copper C101 Max. Depth: 2.75 in. (69.85mm)
CPVC Max. Depth: 2.75 in. (69.85mm)
HDPE Max. Depth: 3.75 in. (95.25mm)
LDPE Max. Depth: 0.75 in. (19mm)
Low Carbon Steel CR 1018 Max. Depth: 1.25 in. (31.75mm)
PA Nylon 6 Max. Depth: 2.75 in. (69.85mm)
PA Nylon 6/6 Max. Depth: 0.75 in. (19mm)
PA Nylon 6/6 (30% GF) Max. Depth: 1.75 in. (44.45mm)
Polycarbonate (Black) Max. Depth: 1.75 in. (44.45mm)
Polycarbonate (Clear) Max. Depth: 1.75 in. (44.45mm)
Polycarbonate (Translucent) Max. Depth: 3.75 in. (95.25mm)
Polycarbonate (20% GF) Max. Depth: 1.75 in. (44.45mm)
PEEK Max. Depth: 1.75 in. (44.45mm)
PEI Ultem 1000 Max. Depth: 2.75 in. (69.85mm)
PEI Ultem 2300 (30% glass-filled) Max. Depth: 1.75 in. (44.45mm)
PET Max. Depth: 2.75 in. (69.85mm)
PMMA (Acrylic) Max. Depth: 2.75 in. (69.85mm)
POM Acetal Homopolymer (Delrin 150) Max. Depth: 3.75 in. (95.25mm)
POM Acetal 20% Glass filled (Delrin 570) Max. Depth: 1.75 in. (44.45mm)
POM Acetal Copolymer Max. Depth: 3.75 in. (95.25mm)
POM Acetal Static Dissipative (Tecaform SD) Max. Depth: 2.75 in. (69.85mm)
PP (Polypropylene Homopolymer) Max. Depth: 2.75 in. (69.85mm)
PP (Polypropylene Copolymer) Max. Depth: 3.75 in. (95.25mm)
PPE/PS (Noryl 265) Max. Depth: 1.75 in. (44.45mm)
PPSU (Radel R 5500) Max. Depth: 1.75 in. (44.45mm)
Polystyrene (PS) Max. Depth: 1.75 in. (44.45mm)
Polysulfone (PSU)  Max. Depth: 1.75 in. (44.45mm)
PTFE (Teflon) Max. Depth: 2.75 in. (69.85mm)
PVC Max. Depth: 3.75 in. (95.25mm)
Stainless Steel 17-4 PH Max. Depth: 1.75 in. (44.45mm)
Stainless Steel 304/304L Max. Depth: 1.75 in. (44.45mm)
Stainless Steel 316/316L Max. Depth: 1.75 in. (44.45mm)
Steel Alloy 4140 Max. Depth: 1.75 in. (44.45mm)
Titanium Ti 6-4 Max. Depth: 1.75 in. (44.45mm)
UHMW Max. Depth: 3.75 in. (95.25mm)
Aluminum 6061-T651 Max. Diameter: 3.95 in. (100mm)
Aluminum 7075-T651 Max. Diameter: 3.95 in. (100mm)
Brass C360 Max. Diameter: 3.95 in. (100mm)
Low Carbon Steel CR 1018 Max. Diameter: 2.95 in. (75mm)
Stainless Steel 17-4 PH Max. Diameter: 2.95 in. (75mm)
Stainless Steel 304/304L Max. Diameter: 2.95 in. (75mm)
Stainless Steel 316/316L Max. Diameter: 2.95 in. (75mm)
Steel Alloy 4140 Max. Diameter: 2.95 in. (75mm)
Titanium Ti 6-4 Max. Diameter: 2.95 in. (75mm)
