Metal Laser Cutting Service
Get custom laser-cut parts in as fast as 1 day. Standard 3-day lead times also available.
Jump to Section
→ Our Process
→ Design Guidelines
→ Materials
→ Laser Cutting Applications
Laser cutting is a manufacturing process where a laser beam pierces raw sheet stock to produce flat geometries. A range of metals are available, which work well for components such as washers, mounts, brackets, and housings.
Laser cutting is commonly used for:
- prototyping designs or testing product requirements
- efficiencies of scale up to 50+ parts
- parts with standard connectivity features (USB, HDMI, ethernet ports)
Our Laser Cutting Process
Our laser cutting service and capabilities are designed around reliably producing quality parts on time.
Online quoting
expand_less expand_more- Upload your CAD file to receive an online quote
- Configure materials, finishes, and additional options in myRapid
Expedited 1-day lead times
expand_less expand_more- Parts can fabricated and shipped in as fast as 1 day
- Standard 3-day lead times for quantities less than 50
Safe parts without sharp edges
expand_less expand_more- Parts deburred and edge debris removed prior to shipping (included in the price)
- Process ensures parts are safe to handle out of the box
One-stop shop for sheet metal components
expand_less expand_more- Formed geometries and geometries with hardware inserts available at 3-day lead times for quantities less than 50
- Basket of sheet metal components ship on same standard lead time
- Flatwork and formed parts produced with one supplier
Highly reliable cutting capability
expand_less expand_more- Fiber optic lasers designed for metal cutting applications (vs. other material types) within thickness range of 0.024 in. – 0.250 in. (0.609mm – 6.35mm)
Manufacturing expertise
expand_less expand_more- Have questions? Work with our team of sheet metal applications engineers to ensure your parts meet your requirements
Laser Cutting Design Guidelines
Follow these guidelines for flat, laser cut parts to ensure quality and accelerate production time.
Maximum Size |
Minimum Part Size | 0.25 in. x 0.25 in. |
Material Thicknesses | 0.024 in. - 0.250 in. |
Tolerances |
Maximum Size |
Minimum Part Size | 6.35mm x 6.35mm |
Material Thicknesses | 0.61mm - 6.35mm |
Tolerances |
Materials and Thicknesses for Laser Cut Parts
We offer the following metal materials for custom laser cut parts. Note that based on material thickness, maximum part size will vary.
Material | Grade | Thicknesses Available |
Aluminum |
0.025 in. - 0.250 in. (0.635mm - 6.35mm) |
Steel |
Stainless Steel |
Copper |
0.025 in - 0.125 in. (0.635mm - 3.175) |
Brass |
0.025 in. - 0.125 in. (0.635mm - 3.175) |
