Compare Injection Molding Materials
*The information contained herein are typical values intended for reference and comparison purposes only. They should NOT be used as a basis for design specifications for quality control.
Additional Links:
Expand Allexpand_all
Collapse Allcollapse_all
AND
AND
AND
Bayblend FR 110
Type: ABS/PC
Color: Black
Flame Rated: 5VA
Impact Resistance
More Detailsexpand_circle_down Less Detailsexpand_circle_up
Bayblend FF110 resin is an easy-flow, flame-retardant blend of Makrolon polycarbonate and acrylonitrile butadiene styrene (ABS) resins. The flame-retardant additive in this grade is antimony/bromine/chlorine-free. Bayblend FR110 exhibits excellent weld-line strength, high heat resistance, and high impact strength. This resin is supplied in pellet form for injection molding applications. It is naturally opaque and available in custom colors and with special visual effects.
Bayblend FR 110
Type: ABS/PC
Color: Natural
Flame Rated: 5VA
Impact Resistance
Bayblend FR110 resin is an easy-flow, flame-retardant blend of Makrolon polycarbonate and acrylonitrile butadiene styrene (ABS) resins. The flame-retardant additive in this grade is antimony/bromine/chlorine-free. Bayblend FR110 exhibits excellent weld-line strength, high heat resistance and high impact strength. This resin is supplied in pellet form for injection molding applications. Natural.
Bayblend FR3010
Type: ABS/PC
Color: Black
Flame Rated: 5VA
Impact Resistance
Chemical Resistant
(PC+ABS)-Blend; flame retardant; Vicat/B 120 temperature = 110°C; increased heat resistance; UL recognition 94 V-0 at 1.5 mm; glow wire temperature (GWFI): 960°C at 2.0 mm; improved chemical resistance and stress cracking behavior; successor to FR2010.
Bayblend FR3010
Type: ABS/PC
Color: White
Flame Rated: 5VA
Impact Resistance
Chemical Resistant
Bayblend FR3010 NAT
Type: ABS/PC
Color: Natural
Flame Rated: 5VA
Impact Resistance
Chemical Resistant
Bayblend T65 XF
Type: ABS/PC
Color: Natural
Flame Rated: HB
Impact Resistance
(PC+ABS)-Blend; Vicat/B 120 temperature = 120C; improved flow compared with T65.
Bayblend T85 XF
Type: ABS/PC
Color: Natural
Flame Rated: HB
Impact Resistance
(PC+ABS)-Blend; Vicat/B 120 temperature = 130C; improved flow compared with T85; natural
Bayblend T85 XF
Type: ABS/PC
Color: Black
Flame Rated: HB
Impact Resistance
(PC+ABS)-Blend; Vicat/B 120 temperature = 130C; improved flow compared with T85; black
Celcon M90
Type: POM (Acetal/Delrin)
Color: Natural
Impact Resistance
Chemical Resistant
Celcon acetal copolymer grade M90 is a medium viscosity polymer providing optimum performance in general purpose injection molding and extrusion of thin walled tubing and thin gauge film. This grade provides overall excellent performance in many applications.
Celcon M90
Color: Black
Impact Resistance
Chemical Resistant
Crastin S600F20
Type: PBT
Color: Black
Flame Rated: HB
Chemical Resistant
Unreinforced, lubricated, medium viscosity polybutylene terephthalate.
Cycolac MG47
Type: ABS
Color: Black
Flame Rated: HB
Impact Resistance
Multi-purpose, injection molding ABS providing a favorable balance of engineering properties.
Cycoloy C1200HF
Type: ABS/PC
Color: Black
Flame Rated: HB
Impact Resistance
PC+ABS, excellent flow/impact/high heat resistance. Low temperature ductility.
Cycoloy C2950
Type: ABS/PC
Color: Black
Flame Rated: 5VB
Impact Resistance
Cycoloy C2950 Polycarbonate/Acrylonitrile Butadiene Styrene (PC/ABS) resin is a standard high heat grade that can be injection molded. This non-chlorinated, non-brominated flame retardant high heat PC/ABS has a UL V0 & 5VB flame rating. Cycoloy C2950 resin is an excellent candidate for a wide variety of applications including appliances, lighting, and electrical.
Cycoloy C2950
Type: ABS/PC
Color: Natural
Flame Rated: 5VB
Impact Resistance
Cycoloy C6200
Type: ABS/PC
Color: Natural
Flame Rated: 5VA
Impact Resistance
PC+ABS, non-chlorinated, non-brominated flame retardant; recommended for thin-wall applications.
Cycoloy C6600-111
Type: ABS/PC
Color: Natural
Flame Rated: 5VB
Impact Resistance
Chemical Resistant
CYCOLOY C6600 polycarbonate/acrylonitrile butadiene styrene (PC/ABS) blend is an injection moldable non chlorinated/brominated flame retardant grade with balanced flow, impact and hydrolytic stability. It also offers good checmial resistance and colorability in opaque colors. It has a UL94 V0@1.5mm and 5VB@2.0mm flame rating.
Delrin 500P
Color: Natural
Flame Rated: HB
Impact Resistance
Chemical Resistant
Medium viscosity acetal homopolymer with improved processing.
Delrin 500P
Color: Black
Flame Rated: HB
Impact Resistance
Chemical Resistant
Delrin 520 MP
Color: Natural
Flame Rated: HB
Impact Resistance
Chemical Resistant
20% PTFE lubricated medium viscosity acetal homopolymer with low wear and low friction.
Delrin 577
Color: Black
Flame Rated: HB
Chemical Resistant
20% glass-filled, medium viscosity homopolymer.
Dow Corning MS-1002
Type: LSR
Color: Clear
High Temp
UV Resistant
Optical / High Clarity
Elastomeric
Chemical Resistant
MS-1002 is a medium viscosity, high Shore A hardness, two-part, 1:1 ratio, fast curing optical molding resin for producing fine detail with good resistance to environmental aging.
Dow DMDA 8907 NT7
Type: HDPE
Color: Natural
UV Resistant
Impact Resistance
Food Grade
Chemical Resistant
DOW DMDA-8907 NT 7 High Density Polyethylene (HDPE) Resin is produced via UNIPOL™ Process Technology from Dow and is intended for use in injection molding applications such as pails, industrial parts and other shipping containers. This resin has been designed to provide excellent processability for molders and to meet the rigorous performance characteristics of applications requiring stackability, environmental stress crack resistance and impact strength.
Dow LDPE 722
Type: LDPE
Color: Natural
Impact Resistance
Food Grade
Dow LDPE 722 is used in flexible packaging and paperboard coating applications such as liquid/juice, laminate tub, condiment pouches, dry foods packaging, snack foods packaging, moist foods packaging, sugar pouches, lidding stock and medical packaging. DOW LDPE extrusion coating resins provide optimal neck-in and draw-down performance with minimal taste/odor contribution. DOW polyethylene 722 is a broad molecular weight distribution homopolymer designed to offer good impact strength and crack resistance, with excellent flexibility. The resin has good processability over a wide range of molding conditions.
Dowlex 2517
Type: LLDPE
Color: Natural
Medical Applications
Food Grade
DOWLEX 2517 Polyethylene Resin is a narrow molecular weight distribution copolymer designed to offer good ESCR and low temperature properties with excellent flexibility. This resin has good processability over a wide range of molding conditions. Linear low density polyethylene. For lids, housewares and containers. Excellent low temperature flexibility, good ESCR.
Eastar 6763
Type: PETG
Color: Clear
Impact Resistance
Food Grade
Sterilizable
Eastar 6763 copolyester meets ISO 10993 and/or USP Class VI biocompatibility requirement; Food Contact Status compliant. Eastar 6763 is a clear, amorphous material that can be molded and extruded with ease. Its excellent performance properties included clarity, toughness, good melt strength, no dusting, no stress whitening, good heat sealability, easy cutting and thermoforming. Eastar 6763 may be colored using color concentrates, dry colors, or liquid colorants. Eastar 6763 can be safely sterilized with proper ethylene oxide, radiation, or electron beam methods without property loss or color shift.
Elastosil 3003/30 A/B
Type: LSR
Color: Clear
High Temp
UV Resistant
Food Grade
Chemical Resistant
Silicone Rubber LSR.
Elastosil 3003/40 A/B
Type: LSR
Color: Clear
High Temp
UV Resistant
Food Grade
Chemical Resistant
Silicone rubber LSR
Elastosil 3003/50 A/B
Type: LSR
Color: Clear
High Temp
UV Resistant
Food Grade
Chemical Resistant
Silicone rubber LSR.
Elastosil 3003/60 A/B
Type: LSR
Color: Clear
High Temp
UV Resistant
Food Grade
Chemical Resistant
Elastosil 3003/70 A/B
Type: LSR
Color: Clear
High Temp
UV Resistant
Food Grade
Chemical Resistant
Elastosil 3003/80 A/B
Type: LSR
Color: Clear
High Temp
UV Resistant
Food Grade
Chemical Resistant
Fortron 1140L4
Type: PPS
Color: Black
Flame Rated: 5VA
High Temp
UV Resistant
Impact Resistance
Chemical Resistant
Fortron 1140L4 is a 40% glass-reinforced grade that is the strongest and toughest product available. It exhibits excellent heat and chemical resistance, good electrical properties and is inherently flame-retardant. The high hardness and rigidity at elevated temperatures allows for good load bearing performance. This product has good weldability due to the modest filler level. Applications made of this grade are electronical components (i.e. bobbins, lamp housings, brush holders) and various other components requiring strength and resistance to aggressive chemicals (i.e. automotive heaters, pump, valves, fuel rails, microwave oven rings and distillation column packings).
Fortron 1140L4 Nat
Type: PPS
Color: Natural
Flame Rated: 5VA
High Temp
UV Resistant
Impact Resistance
Chemical Resistant
Fortron 1140L4 is a 40% glass-reinforced grade that is the strongest and toughest product available. It exhibits excellent heat and chemical resistance, good electrical properties and is inherently flame-retardant. The high hardness and rigidity at elevated temperatures allows for good load bearing performance. This product has good weldability due to the modest filler level. Applications made of this grade are electronical components (i.e. bobbins, lamp housings, brush holders) and various other components requiring strength and resistance to aggressive chemicals (i.e. automotive heaters, pumps, valves, fuel rails, microwave oven rings and distillation column packings).
Grilamid TR55
Type: PA (Nylon)
Color: Clear
Impact Resistance
Food Grade
Chemical Resistant
Grilamid TR55 is a Polyamide 12 (Nylon 12) material. Grilamid TR 55 is flame rated, RoHS compliant, and food contact acceptable and common applications include: medical/healthcare. plumbing/piping/potable water, automotive, film, and food contact applications.
Hylex P1025L
Type: PC
Color: Black
Impact Resistance
Hylon Select N1000EHL BK
Type: PA (Nylon)
Color: Black
Flame Rated: HB
Chemical Resistant
Hylon Select N1013HL
Type: PA (Nylon)
Color: Black
Flame Rated: HB
Chemical Resistant
Hylon Select N1033HL
Type: PA (Nylon)
Color: Black
Flame Rated: HB
Chemical Resistant
Hytrel 3078
Type: TPC-ET
Color: Natural
Flame Rated: HB
UV Resistant
Hytrel 3078 is a very low modulus grade, with nominal hardness of 30D. It contains non-discoloring stabilizer. It can be precessed by many conventional thermoplastic processing techniques like injection molding and extrusion.
Isoplast 202EZ
Type: ETPU
Color: Natural
Food Grade
Chemical Resistant
An engineering thermoplastic polyurethane resin.
K-Resin KR01
Type: SBC
Color: Clear
Impact Resistance
K-Resin KR01 process very well in injection molding, providing good cycle times and design flexibility. Applications range from containers and packaging with living hinges to medical applications, toys, displays, overcaps and hangers. INEOS Styrolution has several grades of KResin SBC tailed for your injection molded needs. Featuring excellent clarity, good stiffness, good toughness, high surface gloss, warpage resistance. Common applications include display housings, medical devices, toys, and molded boxes.
Lexan 121
Type: PC
Color: Infrared Black
Flame Rated: HB
Impact Resistance
UL rated HB. 200 series recommended when V-2 rating required. Nonhalogenated. 17.5 MFR, for small intricate parts.
Lexan 141
Type: PC
Color: Natural
Flame Rated: HB
Impact Resistance
LEXAN 141 resin is a 11 MFR polycarbonate. UL94 HB rated.
Lexan 3412R
Type: PC
Color: Natural
Flame Rated: 5VA
Impact Resistance
20% GR provides improved mechanical properties and UL94 V-1 rated at 0.058 in. Internal mold release added.
Lexan 925U
Type: PC
Color: Black
Flame Rated: V-0
UV Resistant
Impact Resistance
Lexan 925U Polycarbonate (PC) resin is non-filled, injection moldable grade. This non-chlorinated, non-brominated flame retardant PC has an UL-94 V0 rating and is UV stabilized, providing additional weathering capability. Lexan 925U resin is a general purpose resin that is an excellent candidate for a wide variety of applications. Black.
Lexan 940
Type: PC
Color: Black
Flame Rated: V-0
Impact Resistance
Opaque colors, medium viscosity, superior flame retardance.
Lexan 940A
Type: PC
Color: Clear
Flame Rated: V-0
Impact Resistance
LEXAN 940A resin is a 10 MFR polycarbonate. Mold release. Flame retardant, UL94 V0 rated. Clear.
Lexan EXL9330
Type: PC
Color: Black
Flame Rated: 5VA
UV Resistant
Impact Resistance
EXL9330 is an opaque (PC)- siloxane copolymer resin that offers extreme low temperature (-60C) ductility in combination with excellent processability. This UV stabilized, medium flow resin features UL f1/V-0/5VA rating with non-chlorinated, non-brominated flame retardant agents for a wide range of colors. EXL9330 is an excellent candidate for a broad range of applications such as mobile phones, tablets, industrial housings, electric circuit protection, personal safety helmets, electric vehicle supply equipment (EVSE) housings and connectors.
Lexan HP1
Type: PC
Color: Clear
Flame Rated: V-2
Impact Resistance
Sterilizable
LEXAN HP1 is a high flow polycarbonate (PC). This is a biocompatible (ISO10993 or USP Class VI) grade for medical devices and pharmaceutical applications. It is EtO and steam sterilizable, contains mold release and adheres to our healthcare management of change policy.
Liveo C6-550
Type: LSR
Color: Natural
High Temp
UV Resistant
Chemical Resistant
Liquid Silicone Rubber for device and component fabrication in the healthcare industry
Luran S 777K
Type: ASA
Color: Black
Flame Rated: HB
UV Resistant
Impact Resistance
Chemical Resistant
Luran® S 777K is considered as the standard injection molding grade within the Luran S portfolio offering a well-balanced property profile.
Lustran 348
Type: ABS
Color: Natural
Flame Rated: HB
Impact Resistance
*Limited supply available. Contact us to discuss alternative material solutions. Lustran 348 is an injection molding grade of ABS with medium-impact and high-gloss. Features include: healthcare certifications, high gloss, medium impact, FDA modified ISO 10993-1 requirements, US Pharmacopeia 23 Class VI test requirements, UL classification 94HB. Common applications include: Components of intravenous (IV) systems, surgical instruments, diagnostic test kits, UL classification 94HB.
Lustran 348-012002
Type: ABS
Color: Sno White
Flame Rated: HB
Impact Resistance
*Limited supply available. Contact us to discuss alternative material solutions. Lustran 348 resin is an injection molding grade of ABS with medium-impact and high-gloss. Features include: Healthcare certifications, high gloss, medium impact, meets FDA modified ISO 10993-1 requirements, meets US Pharmacopeia 23 Class VI test requirements, and UL classification 94HB. Common applications of Lustran 348 include: Components of intravenous (IV) systems, surgical instruments, diagnostic test kits, and UL classification 94HB.
Lustran 433
Type: ABS
Color: Natural
Flame Rated: HB
Impact Resistance
*Limited supply available. Contact us to discuss alternative material solutions. Lustran 433 is a general-purpose injection molding grade of ABS. It is a high impact, high-gloss ABS, natural.
Lustran 433
Type: ABS
Color: White
Flame Rated: HB
Impact Resistance
*Limited supply available. Contact us to discuss alternative material solutions. Lustran® 433 is a general-purpose injection molding grade of ABS (Acrylonitrile Butadiene Styrene). It is a high impact, high-gloss ABS, available only in natural (NR) and black (BK904000).
Makroblend EL703
Type: PC/PET
Color: Black
Flame Rated: 5VA
UV Resistant
Impact Resistance
Chemical Resistant
(PC+PET) blend; unreinforced; flame-retardant; UV-stabilized; impact modified; high flow; injection molding grade. Good impact strength, dimensional stability and chemical resistance. Uses include outdoor electrical enclosures. UL746C F1 rated.
Makrolon 2258
Type: PC
Color: Clear
Flame Rated: V-2
Impact Resistance
Sterilizable
MVR (300°C/1.2kg) 14c cm³/10 min; medical devices; suitable for ETO and steam sterilization at 121°; biocompatible according to many ISO 10993-1 test requirements; medium viscosity; easy release; injection molding - melt temperature 280 -320°C; available in transparent and opaque colors
Makrolon 2405
Type: PC
Color: Black
Flame Rated: V-2
Impact Resistance
General purpose; low viscosity; easy release; injection molding - melt temperature 280-320 degrees C; black.
Makrolon 2407
Type: PC
Color: Clear
Flame Rated: V-2
UV Resistant
Impact Resistance
General purpose, low viscosity, UV stabilized, easy release, injection molding - melt temperature 280-320C, clear.
Makrolon 2407
Type: PC
Color: Black
Flame Rated: V-2
UV Resistant
Impact Resistance
MVR (300°C/1.2kg) 19 cm³/10 min; general purpose; low viscosity; UV stabilized; easy release; injection molding - melt temperature 280 -320°C; available in transparent, translucent and opaque colors.
Makrolon 2407
Type: PC
Color: Natural Light Diffusion
Flame Rated: V-2
UV Resistant
Impact Resistance
Makrolon 2458
Type: PC
Color: Clear
Impact Resistance
Sterilizable
Medical devices; suitable for ETO and steam sterilization at 121 degrees C; biocompatible according to many ISO 10993-1 test requirements; low viscosity; easy release; injection molding - melt temperature 280-320 degrees C.
Makrolon 2558
Type: PC
Color: Clear
Impact Resistance
Sterilizable
MVR (300C/1.2 kg) 14 cm^3/10 min; medical devices; suitable for ETO and steam sterilization at 121C; biocompatible according to many ISO 10993-1 test requirements; medium viscosity; easy release; injection molding - melt temperature 280-320; clear.
Makrolon 6455
Type: PC
Color: Clear
Flame Rated: V-0
Impact Resistance
Chlorine- and bromine-free flame retardancy, UL 94V-0/3.0 mm; medium viscosity; easy release; injection molding - melt temperature 280-320C; clear.
Makrolon 6485
Type: PC
Color: Black
Flame Rated: 5VA
Impact Resistance
Global grade; flame retardant; UL 94V-0/1.5 mm and 5VA/3.0 mm; medium viscosity; easy release; injection molding - melt temperature 280-320 C; Black
Makrolon 6555
Type: PC
Color: Clear
Flame Rated: V-0
Impact Resistance
Chlorine- and bromine-free flame retardency; UL94V-0/3.0mm; medium viscosity; easy release; injection molding - melt temperature 280-320C.
Makrolon 8325
Type: PC
Color: Black
Flame Rated: V-0
20% glass fiber reinforced; high viscosity; easy release; injection molding - melt temperature 310-330 degrees C; extrusion; black.
Makrolon 9415
Type: PC
Color: Black
Flame Rated: 5VA
10% glass fiber reinforced; flame retardant; UL 94V-0/1.5mm and 5VA/3.0mm; high viscosity; easy release; injection molding - melt temperature 310-330 degrees C; black.
Makrolon RW6265 X
Type: PC
Color: White
Flame Rated: V-0
Impact Resistance
Low viscosity; easy release; flame retardant; variable content of filler for high reflectance application; injection molding.
Makrolon RX1805
Type: PC
Color: Blue Tint
Impact Resistance
Sterilizable
MVR (300°C/1.2kg) 6 cm³/10 min; medical devices; high lipid resistance; suitable for sterilization with high-energy radiation; biocompatible according to many ISO 10993-1 test requirements; high viscosity; injection molding - melt temperature 280 -320°C; transparent parts for medical devices
Makrolon RX2530
Type: PC
Color: Blue Tint
Impact Resistance
Sterilizable
Suitable for sterilization with high-energy radiation; biocompatible according to many ISO 10993-1 test requirements; medium viscosity; injection molding - melt temperature 280-320C, transparent color for use in medical devices.
Marlex 9006
Type: HDPE
Color: Natural
UV Resistant
Impact Resistance
Food Grade
Chemical Resistant
This high density polyethylene is an ethylene-hexene copolymer that is tailored for injection molded applications that require: moderate flow, excellent impact strength, good stiffness, and durability. Typical applications include: industrial pails (five-gallon), pail lids, automotive applications, and foamed parts.
Maxxam FR PP
Type: PP
Color: Black
Flame Rated: V-0
Chemical Resistant
Maxxam FR flame-retardant polyolefin compounds and masterbatches meet stringent flammability performance requirements defined by industry agencies, including Underwriters Laboratories UL 94 V-2, V-0, and 5VA performance ratings. In addition, many compounds in the Maxxam FR portfolio offer elevated Relative Thermal Index (RTI) ratings.
Maxxam PPC-20T
Type: PP
Color: Natural
Impact Resistance
Chemical Resistant
Avient's Maxxam family of polypropylene - and polyethylene-based products covers a wide range of applications, markets and performance requirements. Standard grades are compounded with calcium carbonate, glass and talc to provide a desired balance of properties including stiffness, durability, impact resistance, and heat resistance. Custom grades are available with features such as UV stabilizers, heat stabilizers, custom color, high impact, etc.
Minlon 10B40 BK061
Type: PA (Nylon)
Color: Black
Flame Rated: HB
Chemical Resistant
Minlon 10B40 BK061 is a 40% mineral reinforced black polyamide 66 resin.
Noryl 731F-701S
Type: PPE/PS
Color: Black
Flame Rated: HB
Impact Resistance
Food Grade
Chemical Resistant
Noryl® modified PPO is a strong engineering plastic with outstanding mechanical, thermal, and electrical properties. Low moisture absorption and low thermal expansion make Noryl one of the most dimensionally stable thermoplastics available. Noryl is widely used for electrical housings and structural components since it has excellent insulating properties, flame resistance, and dimensional stability over a wide range of service temperatures.
Noryl 731S
Type: PPE/PS
Color: Black
Impact Resistance
Food Grade
Chemical Resistant
Noryl 73 1S resin is a non-reinforced blend of Polyphenylene (PPE) + polystyrene (PS). This injection molding resin is FC EU, FDA food contact compliant and has NSF/ANSI 61, ACS, WRAS, and KTW-WBGL listings for selected colors and manufacturing locations. Noryl 73 1S resin exhibits good surface appearance, high ductility, low moisture absorption, dimensional and hydrolytic stability. Noryl 73 1S resin is an excellent cadidate for a variety of water management applications such as valves, filtration components, and water meter internals.
Nymax 1010 A
Type: PA (Nylon)
Color: Natural
Impact Resistance
Chemical Resistant
The Nymax® Series of nylon 6 compounds have been specifically developed to deliver outstanding performance in a wide range of application areas. These materials are available with a broad range of fillers, glass reinforcement levels, and impact modifiers depending upon grade selected and have been formulated to offer ease of processing in most standard thermoplastic processing equipment.
Nymax 600 A Zip 43
Type: PA (Nylon)
Color: Natural
Impact Resistance
Food Grade
Chemical Resistant
The Nymax® 600 Blend Series of nylon 6 materials are "salt-and-pepper" pelletized blends combing select nylon resins and process aids, performance modifiers, and color concentrates. These materials have been formulated to provide improved melt processing, part performance, or surface appearance depending upon grade selected and are offered as an economical alternative to fully compounded products.
Nymax GF 1200 A 55 HS Black 13
Type: PA (Nylon)
Color: Black
Heat Stabilized
Impact Resistance
Chemical Resistant
The Nymax® GF 1200 Series of glass fiber-reinforced Nylon 6 compounds have been specifically formulated for applications requiring high stiffness, tensile properties, heat resistance, and durability in harsh environments. These materials are available in a broad range of reinforcement levels depending upon stiffness characteristics desired and have been formulated to offer ease of processing in most standard thermoplastic processing equipment.
Nymax GF 600 A 33 Blk 28 V
Type: PA (Nylon)
Color: Black
Impact Resistance
Chemical Resistant
The Nymax® 600 Series of glass fiber-reinforced Nylon 6 compounds have been specifically engineered for applications requiring high stiffness, tensile strength, and toughness, while providing enhanced surface appearance versus nylon 6/6 compounds. These materials are available in a broad range of reinforcement levels depending upon stiffness characteristics desired and have been formulated to offer ease of processing in most standard thermoplastic processing equipment.
Nymax GF 600 A 33 Nat
Type: PA (Nylon)
Color: Natural
Flame Rated: HB
Impact Resistance
Chemical Resistant
The Nymax® GF 600 Series of glass fiber-reinforced Nylon 6 compounds have been specifically engineered for applications requiring high stiffness, tensile strength, and toughness, while providing enhanced surface appearance versus nylon 6/6 compounds. These materials are available in a broad range of reinforcement levels depending upon stiffness characteristics desired and have been formulated to offer ease of processing in most standard thermoplastic processing equipment.
Nymax GMF 604 40 UV Black 28
Type: PA (Nylon)
Color: Black
UV Resistant
Chemical Resistant
The Nymax® 600 Series of mineral-reinforced nylon 6 compounds have been specifically developed to provide an excellent balance of physical property performance and durability, with improved surface appearance. These materials have been formulated to offer ease of processing in most standard thermoplastic processing equipment.
Pinnacle PP 1112
Type: PP
Color: Natural
Food Grade
Chemical Resistant
Pinnacle Polymers Polypropylene 1112 is made via UNIPOL™ PP technology, which utilizes gas-phase fluidized bed reactors with a high activity catalyst system to ensure uniform physical properties and lot-to-lot consistency. This product is intended for general-purpose injection molding such as resin furniture, closures, and consumer product applications.
Plaslube PE 4000 NAT
Type: UHMWPE
Color: Natural
Impact Resistance
Chemical Resistant
Ultra High Molecular Weight Polyethylene
Plexiglas V825
Type: PMMA (Acrylic)
Color: Clear
Flame Rated: HB
Impact Resistance
Plexiglas V825 is a thermoplastic acrylic resin formulated for injection molding and extrusion applications. It is characterized by its high heat resistance and high melt flow. Plexiglas V825 has excellent weatherability and optical properties allowing it to excel in applications requiring outdoor stability, high quality surface appearance and/or precision optics. Plexiglas V825 is easy to process due to its exceptional thermal stability, extrusion melt strength, and excellent tool surface reproduction and release properties. Moldflow simulation data is available. It has excellent resistance to many chemicals including solutions of inorganic acids, alkalis and aliphatic hydrocarbons such as VM&P naphtha and heptane. Additionally, it is virtually unaffected by a wide range of commercial products including many beverages, foodstuffs, detergent solutions, and cleaners.
Polyac PA 765
Type: ABS
Color: Black
Flame Rated: 5VA
Impact Resistance
High Flow
Polyac PA-765
Type: ABS
Color: Natural
Flame Rated: 5VA
Impact Resistance
F.R. High Flow.
Polylac PA-746
Type: ABS
Color: Black
Flame Rated: HB
Impact Resistance
POLYLAC PA-746 is an acrylonitrile butadiene styrene (ABS) product that offers flame rating, RoHS compliance, impact resistance and has a high flow.
Profax 6323
Type: PP
Color: Natural
Chemical Resistant
Profax 6323 general purpose polypropylene homopolymer is available in pellet form. This resin is typically used in injection molding applications.
Profax 6523
Type: PP
Color: Natural
Flame Rated: HB
Chemical Resistant
Profax 6523 general purpose polypropylene homopolymer resin is available in pellet form.
Profax PD702
Type: PP
Color: Natural
Chemical Resistant
Pro-fax PD702 polypropylene homopolymer is available in pellet form. This resin is typically used in injection molding applications.
Profax SG-702
Type: PP
Color: Natural
Impact Resistance
Chemical Resistant
Pro-fax SG702 high impact polypropylene copolymer is available in pellet form. This resin is typically used in injection molding applications and offers very good cold temperature resistance.
Profax SR549M
Type: PP
Color: Clear
Impact Resistance
Food Grade
Chemical Resistant
Pro-fax SR549M clarified polypropylene rancom copolymer is available in pellet form. This resin is typically used in injection molding and injection-stretch blow bolding applications and offers good see-through and contact clarity.
Pulse 2000EZ
Type: ABS/PC
Color: Natural
Impact Resistance
PULSE 2000EZ is a high-heat PC/ABS resin delivering optimized performance for automotive interior component applications.
Radel R-5000 NT
Type: PPSU
Color: Natural Transparent
Flame Rated: V-0
High Temp
UV Resistant
Impact Resistance
Food Grade
Chemical Resistant
Sterilizable
Radel R-5000 is a transparent polyphenylsulfone (PPSU) which offers exceptional hydrolytic stability, and toughness superior to other commercially-available, high-temperature engineering resins. This resin also offer high deflection temperatures and outstanding resistance to environmental stress cracking. Radel polymers are inherently flame retardant, provide excellent thermal stability and possess good electrical properties.
Radel R-5100
Type: PPSU
Color: Black
Flame Rated: V-0
High Temp
UV Resistant
Impact Resistance
Food Grade
Sterilizable
Chemical Resistant
Radel R-5100 is an opaque, general purpose polyphenylsulfone (PPSU) for injection molding, that offers exceptional hydrolytic stability, and toughness superior to other commercially-available, high-temperature engineering resins. This resin also offers a high deflection temperature and outstanding resistance to environmental stress cracking. Radel polymers are inherently flame retardant, provide excellent thermal stability and possess good electrical properties.
Radel R-5100 BU1027
Type: PPSU
Color: Blue
Flame Rated: V-0
High Temp
UV Resistant
Impact Resistance
Food Grade
Sterilizable
Chemical Resistant
Radel R-1500 is an opaque, general purpose polyphenylsulfone (PPSU) for injection molding, that offers exceptional hydrolytic stability, and toughness superior to other commercially available, high-temperature engineering resins. This resin also offers a high deflection temperature and outstanding resistance to environmental stress cracking. Radel polymers are inherently flame retardant, provide excellent thermal stability and possess good electrical properties.
Radel R-5100 GY1037
Type: PPSU
Color: Gray
Flame Rated: V-0
High Temp
UV Resistant
Impact Resistance
Food Grade
Chemical Resistant
Sterilizable
Radel R-5100 NT15
Type: PPSU
Color: Off-White
Flame Rated: V-0
High Temp
UV Resistant
Impact Resistance
Food Grade
Chemical Resistant
Sterilizable
RTP 150 CC FR A
Type: PP
Color: Natural
Flame Rated: V-0
Chemical Resistant
RTP 200
Type: PA (Nylon)
Color: Black
Flame Rated: V-2
UV Resistant
Chemical Resistant
RTP 200 UV is a UV stabilized nylon 6/6 general purpose resin.
RTP 200 UV
Type: PA (Nylon)
Color: Natural
Flame Rated: V-0
Chemical Resistant
RTP 200 UV is a UV stabilized nylon 6/6 general purpose resin. The status of this material is "commercial: limited use".
RTP 203 FR
Type: PA (Nylon)
Color: Black
Flame Rated: V-0
Chemical Resistant
20% Glass fiber reinforced.
RTP 204 UV
Type: PA (Nylon)
Color: Black
Flame Rated: HB
UV Resistant
Chemical Resistant
25% glass fiber reinforced.
RTP 2100 LF
Type: PEI
Color: Black
Flame Rated: V-0
High Temp
UV Resistant
Impact Resistance
Chemical Resistant
RTP 301
Type: PC
Color: Natural
Flame Rated: HB
RTP 605
Type: ABS
Color: Black
Flame Rated: HB
RTP 800 GB 10
Color: Black
Flame Rated: HB
Chemical Resistant
Black 10% Glass Bead Acetal.
RTP 800 GB 20
Color: Black
Flame Rated: HB
Chemical Resistant
Black 20% Glass Bead Acetal.
RTP ESD C 380 FR L
Type: PC
Color: Black
Flame Rated: V-0
Electrically Conductive
Rynite 530
Type: PET
Color: Black
Flame Rated: HB
30% glass reinforced polyethylene terephthalate.
Rynite 935
Type: PET
Color: Black
Flame Rated: HB
35% glass/mica reinforced polyethylene terephthalate.
Rynite FR 945
Type: PET
Color: Black
Flame Rated: 5VA
45% glass/mineral reinforced, flame retardant, polyethylene terephthalate.
Rynite FR515 BK507
Type: PET
Color: Black
Flame Rated: 5VA
Heat Stabilized
15% Glass Reinforced, Flame Retardant, Polyethylene Terephthalate.
Rynite FR530
Type: PET
Color: Natural
Flame Rated: V-0
High Temp
30% glass reinforced, flame retardant, polyethylene terephthalate.
Rynite FR530 BK507A
Type: PET
Color: Black
Flame Rated: 5VA
30% glass reinforced, flame retardant polyethylene terephthalate.
Ryton R-4
Type: PPS
Color: Natural
Flame Rated: 5VA
High Temp
UV Resistant
Impact Resistance
Chemical Resistant
Ryton R-4-200NA 40% glass fiber polyphenylene sulfide compounds provide enhanced mechanical strength and low maintenance molding using conventional molding equipment.
Ryton R-4-200BL
Type: PPS
Color: Black
Flame Rated: 5VA
High Temp
UV Resistant
Impact Resistance
Chemical Resistant
Ryton® R-4-200NA and R-4-200BL 40% glass fiber reinforced polyphenylene sulfide compounds provide enhanced mechanical strength and low maintenance molding using conventional molding equipment
Ryton R-4-200NA
Type: PPS
Color: Natural
Flame Rated: 5VA
High Temp
UV Resistant
Impact Resistance
Chemical Resistant
Ryton® R-4-200NA and R-4-200BL 40% glass fiber reinforced polyphenylene sulfide compounds provide enhanced mechanical strength and low maintenance molding using conventional molding equipment.
Santoprene 101-55
Type: TPE/TPV
Color: Black
Flame Rated: HB
UV Resistant
Chemical Resistant
A soft, black, versatile thermoplastic vulcanizate (TPV) in the thermoplastic elastomer (TPE) family. This material combines good physical properties and chemical resistance for use in a wide range of applications. This grade of Santoprene TPV is shear-dependent and can be processed on conventional thermoplastics equipment for injection molding or extrusion. It is polyolefin based and recyclable within the manufacturing stream.
Santoprene 101-64
Type: TPE/TPV
Color: Black
Flame Rated: HB
UV Resistant
Elastomeric
Chemical Resistant
A soft, black, versatile thermoplastic vulcanizate (TPV) in the thermoplastic elastomer (TPE) family. This material combines good physical properties and chemical resistance for use in a wide range of applications. This grade of Santoprene® TPV is shear-dependent and can be processed on conventional thermoplastics equipment for injection molding, extrusion or blow molding. It is polyolefin based and recyclable within the manufacturing stream.
Santoprene 101-73
Type: TPE/TPV
Color: Black
Flame Rated: HB
UV Resistant
Elastomeric
Chemical Resistant
Santoprene 101-87
Type: TPE/TPV
Color: Black
Flame Rated: HB
UV Resistant
Chemical Resistant
A hard, black, versatile thermoplastic vulcanizate (TPV) in the thermoplastic elastomer (TPE) family. This material combines good physical properties and chemical resistance for use in a wide range of applications. This grade of Santoprene TPV is shear-dependent and can be processed on conventional thermoplastics equipment for injection molding, extrusion, blow molding, thermoforming or vacuum forming. It is polyolefin based and recyclable within the manufacturing stream.
Santoprene 111-35
Type: TPE/TPV
Color: Black
Flame Rated: HB
UV Resistant
Chemical Resistant
A soft, black, versatile thermoplastic vulcanizate (TPV) in the thermoplastic elastomer (TPE) family. This material combines good physical properties and chemical resistance for use in a wide range of injection molding applications. This grade of Santoprene TPV is shear-dependent and can be processed on conventional thermoplastics equipment for injection molding. It is polyolefin based and recyclable within the manufacturing stream.
Santoprene 111-45
Type: TPE/TPV
Color: Black
Flame Rated: HB
UV Resistant
Elastomeric
Chemical Resistant
A soft, black, versatile thermoplastic vulcanizate (TPV) in the thermoplastic elastomer (TPE) family. This material combines good physical properties and chemical resistance for use in a wide range of injection molding applications. This grade of Santoprene® TPV is shear-dependent and can be processed on conventional thermoplastics equipment for injection molding. It is polyolefin based and recyclable within the manufacturing stream.
Santoprene 201
Type: TPE/TPV
Color: Natural
Flame Rated: HB
UV Resistant
Chemical Resistant
A soft, colorable, versatile thermoplastic vulcanizate (TPV) in the thermoplastic elastomer (TPE) family. This material combines good physical properties and chemical resistance for use in a wide range of applications. The grade of Santoprene A TPVis a shear-dependent and can be processed on conventional thermoplastics equipment for injection molding or extrusion. It is polyolefin based and recyclable within the manufacturing stream.
Santoprene 201-55
Type: TPE/TPV
Color: Natural
Flame Rated: HB
UV Resistant
Chemical Resistant
A soft, colorable, versatile thermoplastic vulcanizate (TPV) in the thermoplastic elastomer (TPE) family. This material combines good physical properties and chemical resistance for use in a wide range of applications. This grade of Santoprene A TPV is shear-dependent and can be processed on conventional thermoplastics equipment for injection molding or extrusion. It is polyolefin based and recyclable within the manufacturing stream. Recommended for applications requiring excellent flex fatigue resistance, excellent ozone resistance.
Santoprene 201-87
Type: TPE/TPV
Color: Natural
Flame Rated: HB
Impact Resistance
Chemical Resistant
A hard, colorable, versatile thermoplastic vulcanizate (TPV) in the thermoplastic elastomer (TPE) family. This material combines good physical properties and chemical resistance for use in a wide range of applications. This grade of Santoprene TPV is shear-dependent and can be processed on conventional thermoplastics equipment for injection molding, extrusion, blow molding, thermoforming or vacuum forming. It is polyolefin based and recyclable within the manufacturing stream.
Santoprene 211-45
Type: TPE/TPV
Color: Natural
Flame Rated: HB
UV Resistant
Elastomeric
Chemical Resistant
A soft, colorable, versatile thermoplastic vulcanizate (TPV) in the thermoplastic elastomer (TPE) family. This material combines good physical properties and chemical resistance for use in a wide range of injection molding applications. This grade of Santoprene® TPV is shear-dependent and can be processed on conventional thermoplastics equipment for injection molding. It is polyolefin based and recyclable within the manufacturing stream.
Santoprene 251-70W232
Type: TPE/TPV
Color: Natural
Flame Rated: V-0
A soft, colorable, flame retardant thermoplastic vulcanizate (TPV) in the thermoplastic elastomer (TPE) family. This material has good fluid resistance and contains non-ether brominated flame retardant. It does not contain metal deactivators. This grade of Santoprene TPV is shear-dependent and can be processed on conventional thermoplastics equipment for injection molding, extrusion, or blow molding. It is polyolefin based and recyclable within the manufacturing stream.
Silastic FL 60-9201
Type: F-LSR
Color: Natural
High Temp
UV Resistant
Chemical Resistant
Features excellent resistance against automotive fuels and oils, fast cure platinum technology, cures over a wide temperature range and high temperature resistance.
Stanyl TW341
Type: PA (Nylon)
Color: Natural
Flame Rated: V-2
Heat Stabilized
Impact Resistance
Chemical Resistant
Styron 498
Type: PS
Color: Natural
Flame Rated: HB
Impact Resistance
Food Grade
High impact polystyrene: high gloss, high impact, food contact compliant, UL classification 94 HB. Typical applications: Appliances, housewares, consumer electronics, medical.
Styron 666D
Type: PS
Color: Clear
Flame Rated: HB
Food Grade
Styron 666D offers medium heat resistance, medium flow, food contact compliance, UL classification 94 HB, and USP class VI. It is often used in medical and packaging applications.
Terluran GP-22
Type: ABS
Color: Natural
Flame Rated: HB
Impact Resistance
Food Grade
Terluran GP-22 is an easy-flow, general purpose injection molding grade with high resistance to impact and heat distortion; intended for a wide range of applications, particularly in the housings sector. Features include: excellent colorability, medium flow, good impact resistance, good heat distortion resistance, high quality surface finish and gloss, great mechanical strength and rigidity. Common applications for Terluran GP-22 include: injection molding, appliance housings, household and sanitary appliances, toys, automotive components, and consumer products.
Texin 245D
Type: TPU
Color: Natural
Impact Resistance
Chemical Resistant
Texin 245D resin is an aromatic polyester-based thermoplastic polyurethane with a Shore hardness of approximately 43D. It can be processed by injection molding; extrusion processes are not recommended.
Texin 983A
Type: TPU
Color: Natural
Impact Resistance
Food Grade
Chemical Resistant
Texin 983A resin offers outstanding abrasion resistance, impact strength, toughness, and flexibility. It also exhibits hydrolytic stability. Texin 983A complies with FDA food-contact regulations 21 CFR 177.1680 and 177.2600, subject to limitations of these and other applicable regulations. Applications including belting, hose, seals and gaskets, tubing, cable jackets, hose jackets, athletic soles, casters, mine screens, film, and extruded profiles.
Thermylene P6-30FG-0600
Type: PP
Color: Natural
Flame Rated: HB
Heat Stabilized
Chemical Resistant
This general purpose polypropylene compound has been heat stabilized for underhood applications.
Tritan MX711
Type: Copolyester
Color: Clear
Impact Resistance
Chemical Resistant
Sterilizable
Eastman Tritan™ MX711 copolyester is an amorphous product with excellent appearance and clarity. Tritan MX711 contains a mold release derived from vegetable based sources. Tritan MX711 has many outstanding features that include excellent toughness, hydrolytic stability, heat resistance, and chemical resistance. Tritan MX711 has been formulated for medical devices. Tritan MX711 has been tested for FDA/ISO 10993 and USP Class VI Biological Evaluation testing after Gamma and ETO sterilization.
Tritan MX731
Type: Copolyester
Color: Clear
Impact Resistance
Chemical Resistant
Sterilizable
Eastman Tritan™ Copolyester MX731 is an amorphous product with excellent appearance and clarity. Eastman Tritan Copolyester MX731 is a high flow medical grade of Eastman Tritan that has viscosity reductions of 40-50% relative to Eastman Tritan Copolyester MX711. Eastman Tritan Copolyester MX731 contains a mold release derived from vegetable based sources. Eastman Tritan Copolyester MX731 has many outstanding features that include excellent toughness, hydrolytic stability, heat resistance, chemical resistance, and melt flowability. Eastman Tritan Copolyester MX731 has been formulated for medical devices. Eastman Tritan Copolyester MX731 has been tested for FDA/ISO 10993 and USP Class VI Biological Evaluation testing after Gamma and ETO sterilization.
Tritan TX1001
Type: Copolyester
Color: Clear
Impact Resistance
Food Grade
Chemical Resistant
Eastman Tritan TX1001 is an amorphous copolyester with excellent appearance and clarity. Tritan TX1001 contains a mold release derived from vegetable based sources. Its most outstanding features are excellent toughness, hydrolytic stability, and heat and chemical resistance. This new-generation copolyester can also be molded into various applications without incorporating high levels of residual stress. Combined with Tritan's outstanding chemical resistance and hydrolytic stability, these features give molded products enhanced durability in the dishwasher environment, which can expose products to high heat, humidity and aggressive cleaning detergents. Tritan TX1001 may be used in repeated use food contact articles under FDA regulations. Tritan TX1001 is certified to NSF/ANSI Standard 51 for Food Equipment Materials and is also certified to NSF/ANSI 61 - Drinking Water Systems Components-Health Effects.
Udel P-1700
Type: PSU
Color: Natural
Flame Rated: V-0
High Temp
Impact Resistance
Sterilizable
Chemical Resistant
Udel P-1700 polysulfone (PSU) is a tough, rigid, high-strength thermoplastic suitable for continuous use up to 300F (149C). It is resistant to oxidation and hydrolysis and withstands prolonged exposure to high temperatures and repeated sterilization. Udel P-1700 polysulfone is highly resistant to mineral acids, alkali and salt solutions. Resistance to detergents and hydrocarbon oils is good, but may be attacked by polar solvents such as ketones, chlorinated hydrocarbons and aromatic hydrocarbons. These resins are also high resistant to degradation by gamma or electron beam radiation. Electrical properties of Udel P-1700 polysulfones are stable over a wide temperature range and after immersion in water or exposure to high humidity.
Udel P-3703 NT 11
Type: PSU
Color: Natural
High Temp
Impact Resistance
Chemical Resistant
Sterilizable
Udel P-3703 is a high-flow grade of polysulfone intended for injection molding applications with thin walls or long flow lengths. This grade has higher flow than Udel P-1700 and a slightly higher tendency to stress crack in some aggressive environments. Udel polysulfone is a tough, rigid, high-strength thermoplastic that maintains its properties at temperatures from -101C to 149C (-150F to 300F). The heat deflection temperature at 1.8 MPa (264 psi) is 174C (345F). For most purposes, this resin is suitable for continuous use up to 149C (300F). The material is resistant to oxidation and hydrolysis and withstands prolonged exposure to high temperatures and repeated sterilization. Udel polysulfone is highly resistant to mineral acids, alkali, and salt solutions. The resistance to detergents and hydrocarbon oils is good, but it will be attacked by polar solvents such as ketones, chlorinated hydrocarbons, and aromatic hydrocarbons. Electrical properties of Udel polysulfone are stable over a wide temperature range and after immersion in water or exposure to high humdity.
Ultem 1000
Type: PEI
Color: Black
Flame Rated: 5VA
High Temp
UV Resistant
Impact Resistance
Chemical Resistant
ULTEM 1000 resin is an amorphous, transparent polyetherimide (PEI) plastic offering a glass transition temperature (Tg) of 217C. This inherently flame retardant resin has UL94 V0, V2 and 5VA ratings and is RoHS compliant. ULTEM 1000 resin is an unreinforced general purpose grade offering high heat resistance, high strength, and modulus and broad chemical up to high temperatures
Ultem 1000
Type: PEI
Color: Natural
Flame Rated: 5VA
High Temp
UV Resistant
Impact Resistance
Chemical Resistant
ULTEM 1000 resin is an amorphous, transparent polyetherimide (PEI) plastic offering a glass transition (Tg) of 217C. This inherently flame retardant resin has UL94 V0, V2, and 5VA ratings and is RoHS compliant. ULTEM 1000 resin is an unreinforced general purpose grade offering high heat resistance, high strength and modulus and broad chemical resistance up to high temperatures.
Ultem 2200
Type: PEI
Color: Natural
Flame Rated: 5VA
High Temp
UV Resistant
Impact Resistance
Food Grade
Chemical Resistant
20% glass fiber filled, standard flow polyetherimide. ECO conforming, UL94 V0 and 5VA listing.
Ultem 2300
Type: PEI
Color: Black
Flame Rated: 5VA
High Temp
UV Resistant
Impact Resistance
Food Grade
Chemical Resistant
30% glass fiber filled, standard flow Polyetherimide (Tg 217C). ECO conforming, UL94 V0 and 5VA listing. NSF 51 listing, WRAS certification, KTW certification in recognized colors.
Valox 357
Type: PBT
Color: Black
Flame Rated: 5VA
Impact Resistance
Chemical Resistant
VALOX 357 Polycarbonate/Polybutylene Terephthalate (PC/PBT) resin is a non-reinforced, impact modified, injection moldable grade. This brominated flame retardant PC/PBT has a UL V0 rating. VALOX 357 resin is a general purpose resin that is an excellent candidate for a wide variety of applications including bobbins, switches and enclosures.
Valox 357
Type: PBT
Color: Natural
Flame Rated: 5VA
Impact Resistance
Chemical Resistant
VALOX 357 polycarbonate/polybutylene therephthalate (PC/PBT) resin is a non-reinforced, impact modified, injection moldable grade. This brominated flame retardant PC/PBT has a UL V0 rating. VALOX 357 resin is a general purpose resin that is an excellent candidate for a wide variety of applications including bobbins, switches, and enclosures.
Valox 420 SEO
Type: PBT
Color: Natural
Flame Rated: 5VA
Chemical Resistant
VALOX 420SEO Polybutylene Terephthalate (PBT) resin is a 30% glass fiber reinforced, injection moldable grade. This brominated flame retardant PBT ha a UL V0 and 5VA rating. VALOX 420SEO resin is a general purpose resin that is an excellent candidate for a wide variety of application including electrical components, bobbins, switches, stators, commutators and cooling fans.
Valox 420SEO
Type: PBT
Color: Black
Flame Rated: 5VA
Chemical Resistant
VALOX 420SEO Polybutylene Terephthalate (PBT) resin is a 30% glass fiber reinforced, injection moldable grade. This brominate flame retardant PBT has a UL V0 and 5VA rating. VALOX 420SEO resin is a general purpose resin that is an excellent candidate for a wide variety of applications including electrical components, bobbins, switches, stators, commutators and cooling fans.
Vectra E130I
Type: LCP
Color: Black
Flame Rated: V-0
High Temp
UV Resistant
Chemical Resistant
30% glass fiber, excellent flow, high temperature capability. Suitable where very thin walls are required. Used for broad range of SMT applications, with minimal dimensional change. Inherently flame retardant UL-listing V-0 in natural and black at 0.2mm thickness per UL94 flame testing.
Vectra E130I
Type: LCP
Color: Natural
Flame Rated: V-0
High Temp
Impact Resistance
Chemical Resistant
30% glass fiber, excellent flow, high temperature capability. Suitable where very thin walls are required. Used for a broad range of SMT applications, with minimal dimensional change.
Versaflex CL2250
Type: TPE/TPV
Color: Clear
Versaflex™ CL2250 is an easy processing compound designed for use in injection molding applications where FDA compliance, clarity and ehanced heat resistance are required.
Versaflex OM 1040X-1
Type: TPE/TPV
Color: Natural
The Versaflex OM 1040X-1 is a medical compliant over molding TPE with very good adhesion to PC or ABS-based plastics. Offers good surface aesthetics, rubbery feel, and soft touch.
Versaflex OM 1060X-1
Type: TPE/TPV
Color: Natural
Versaflex OM 1060X-1 is an over molding TPE with very good adhesion to PC or ABS-based plastics. Offering good surface aesthetics, rubbery feel, and soft touch.
Versaflex OM 6240-1
Type: TPE/TPV
Color: Natural
Versaflex OM 6240-1 is specifically designed to bond a variety of standard and modified nylon materials, including those which are glass-filled, heat stabilized, and/or impact modified. Versaflex OM 6240-1 offers exceptional colorability, outstanding adhesion in two-shot molding processes, and soft, rubbery grip.
Versaflex OM 6258-1
Type: TPE/TPV
Color: Natural
Versaflex OM 6258-1 is specifically designed to bond to a variety of standard and modified nylon materials, including those which are glass-filled, heat stabilized, and/or impact modified. Versaflex OM 6258-1 offers exceptional colorability, outstanding adhesion in both two-shot and insert molding processes, and soft, rubbery grip.
Victrex 450G
Type: PEEK
Color: Natural
High Temp
Impact Resistance
Food Grade
Chemical Resistant
Sterilizable
High-performance thermoplastic material, unreinforced PolyEtherEtherKetone (PEEK), semi-crystalline, granules for injection molding and extrusion, standard flow, FDA food contact compliant, natural color. Applications for higher strength and stiffness as well as high ductility. Chemically resistant to aggressive environments, suitable for sterilization for medical and food contact applications.
Vydyne R533H
Type: PA (Nylon)
Color: Black
Flame Rated: HB
Heat Stabilized
Chemical Resistant
The Vydyne R533 Series of 33% glass fiber reinforced nylons are available in black and heat stabilized versions. They are general purpose, injection molding grades which are lubricated for good machine feed, flow and mold release. Vydyne R533 Series resins have tensile strength and modulus properties just below aluminum and zinc and can replace these metals in numerous applications due to an excellent balance of properties. Reduction in production costs, energy consumption, and part weight are key advantages of Vydyne glass reinforced Nylon 6,6 resins over aluminum and/or zinc die cast parts. Vydyne R533H is a heat stabilized grade, formulated to minimize the oxidative and thermal degradation of the nylon polymer when exposed to elevated temperatures for extended periods of time. Vydyne R533H provides improved retention of physical properties under exposure to long-term heat. The continuous operating use temperature is 275F and short-term peak temperatures as high as 475F.
Xenoy 6620
Type: PC/PBT
Color: Black
Flame Rated: HB
Impact Resistance
PBT+PC, unreinforced, impact modified thermoplastic alloy. Outstanding impact at low temperature.
Zytel 101L
Type: PA (Nylon)
Color: Black
Flame Rated: V-2
Impact Resistance
Chemical Resistant
Unreinforced polyamide 66.
Zytel 101L
Type: PA (Nylon)
Color: Natural
Flame Rated: V-2
Impact Resistance
Chemical Resistant
Zytel 103HSL
Type: PA (Nylon)
Color: Natural
Flame Rated: V-2
Heat Stabilized
Impact Resistance
Chemical Resistant
Unreinforced, heat stabilized, polyamide 66.
Zytel 70G13 HS1L BK031
Type: PA (Nylon)
Color: Black
Flame Rated: HB
Heat Stabilized
Chemical Resistant
Zytel 70G13 HS1L BK031 si a 13% glass fiber reinforced, heat stabilized, black polyamide 66 resin for injection molding.
Zytel 70G13 HS1L NC010
Type: PA (Nylon)
Color: Natural
Flame Rated: HB
Heat Stabilized
Chemical Resistant
Zytel 70G13 HS1L NC010 is a 13% glass fiber reinforced, heat stabilized, black polyamide 66 resin for injection molding.
Zytel 70G33HS1L
Type: PA (Nylon)
Color: Natural
Flame Rated: HB
Heat Stabilized
Chemical Resistant
Zytel 70G33HS1L is a 33% glass fiber reinforced, heat stabilized, natural polyamide 66 resin for injection molding.
Zytel 70G33HS1L BK031
Type: PA (Nylon)
Color: Black
Flame Rated: HB
Heat Stabilized
Chemical Resistant
Zytel 70G33HS1L BK031 is a 33% glass fiber reinforced, heat stabilized, black polyamide 66 resin for injection molding.
Zytel 7335F NC010
Type: PA (Nylon)
Color: Natural
Flame Rated: HB
Impact Resistance
Chemical Resistant
Unreinforced nucleated polyamide 6.
Zytel 73G15L
Type: PA (Nylon)
Color: Natural
Flame Rated: HB
Chemical Resistant
15% glass reinforced polyamide 6.
Zytel 77G33L
Type: PA (Nylon)
Color: Black
Flame Rated: HB
Chemical Resistant
33% glass reinforced polyamide 612.
Zytel 8018 HS
Type: PA (Nylon)
Color: Black
Flame Rated: HB
Impact Resistance
Chemical Resistant
Zytel 80G14AHS BK099
Type: PA (Nylon)
Color: Black
Heat Stabilized
Impact Resistance
Chemical Resistant
Zytel® 80G14AHS NC010 is a 14% glass fiber reinforced, toughened, high flow, heat stabilized polyamide 66 resin. It offers outstanding performance in injection molding applications.
Zytel 80G14AHS NC010
Type: PA (Nylon)
Color: Natural
Flame Rated: HB
Heat Stabilized
Chemical Resistant
Zytel FR50 BK505
Type: PA (Nylon)
Color: Black
Flame Rated: 5VA
Impact Resistance
Chemical Resistant
25% glass reinforced, flame retardant, polyamide 66.
Zytel FR7026V0F BK001
Type: PA (Nylon)
Color: Black
Flame Rated: V-0
Impact Resistance
Chemical Resistant
Unreinforced, Flame Retardant, Elemental Phosphorous Free, Heat Stabilized, Polyamide 66, Non-Chlorine; Non-Bromine Material.
Zytel HTN 51G35HSL BK083
Type: PPA
Color: Black
Flame Rated: HB
High Temp
Heat Stabilized
Impact Resistance
Chemical Resistant
Zytel HTN51G35HSL is a 35% glass reinforced, heat stabilized, lubricated high performance polyamide resin. It is also a PPA resin.
Zytel HTN 51G35HSL NC101
Type: PPA
Color: Natural
Flame Rated: HB
High Temp
Heat Stabilized
Impact Resistance
Chemical Resistant
Zytel HTN 51G35HSL NC101 is a 35% glass reinforced, heat stabilized, lubricated high performance polyamide resin. It is also a PPA resin.
Zytel ST801
Type: PA (Nylon)
Color: Natural
Flame Rated: HB
Impact Resistance
Chemical Resistant
Zytel ST801 is a general purpose Super Tough nylon 66 resin. It offers outstanding impact resistance and high productivity.
Zytel ST801
Type: PA (Nylon)
Color: Black
Flame Rated: HB
Heat Stabilized
Impact Resistance
Chemical Resistant
Zytel ST801 NC010A is a general purpose Super Tough nylon 66 resin. It offers outstanding impact resistance and high productivity.
There are no materials that match the selected combination of filters.
